Synchronize archive
dominoforever
Hey,
I would like to backup the config of all devices but I have an error whan I launch the Sync Archive.
See the error below:
The following is the status of your Sync Archive job:
Job ID         : 1637
Status         : Job Failed(1)
Description   : test sync
Details       : http://ciscolms.domain.local:1741/rme/DcmaJobDetails.do?jobid=1637
Start Date and Time : Mon Aug 08 11:02:14 CEST 2011
End Date and Time   : Mon Aug 08 11:03:23 CEST 2011
RME Server Name/IP : ciscolms.domain.local
Execution Summary
Pending         : 0
NotAttempted     : 0
Successful       : 0
Failed           : 1
Partial Success : 0
I don't know if I forgot something, could you please help me?
Kind regards,
Sébastien
45 Replies 45
Hi Seb,
Thanks for the update. As the job has started working for 3 devices ,kindly check the device credentilas verfication repot for the Failing device and just make sure you have the Correct Credentilas defined.
If everything looks like fine ,, send me the screen shot of CDA job and send me the new dcmaservice.log
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
I launched the check device credential status for all devices and I have no errors. The credentials are correct, I modified the credentials for 2 devices who I doesn't work.
See the log file attached.
Thanks.
Hi seb,
try deleting and Re-adding a device in RME and re run the job (  ONly for a single problematic device)
--Make sure you clear the dcmaservice.log before you ran this new job.
and if the job still fail then send me the new dcmaservice.log
Afroj
Hi Afroj,
I deleted one device who doesn't work. I re-added it on the LMS and run the job but I always have an error.
See the log file.
I have seen some device in the file log like 192.168.254.111, 192.168.254.112, 192.168.254.113, 192.9.254.71. That's the devices who successed to backup config.
Thanks.
Hi Seb,
Log file does not have much logs ,it's incomplete ,kindly check the logfile and resend me the log file.
Afroj
Hi Afroj,
I tried a new archive sync this morning for the devices which worked last week, but it doesn't work!!!
I check the credentials and launched an export, I have the right login + password. I made a check device credential reports and I haven't any errors.
Have you an idea?
Thanks.
Hi Seb,
From the logs it looks like the Process are not running..
Check the process status with pdshow command (check if JRM and CTMJRMServer is running Normally )
If not try Re-booting the Server and then chekc the status
Afroj
Hi Afroj!
I restarted the server before you posted your message and since the archive sync work fine!! I backuped all my
Cisco devices!
Great job, thank you for your help!
Kind regards,
Seb
Hi Seb,
Great   n Thanks for the update.
If this post answers your question, please click the "Correct Answer" button"
Afroj
Thanks Afroj,
I have a question about the backup files with archive sync. Is there a way to keep more than one versions of each backup config files?
Yes it is possible. kindly check the attached the screenshot :
Afroj
Thank you Afroj.
If I go to the folder where the cfg files are created, I just have one file for each switch. I went to the Config Editor, and here I can see 4 archive files for one switch. Is it normal that I see only one cfg file in the folder, how can I see all versions?
Thanks.
Hi seb,
From the GUI , you can see all the version under VERSION TREE
On the server :
go to NMSROOT\CSCOpx\files\rme\dcma
I hope this will help
Afroj
I juste have a question about archive synchronize. I scheduled a few jobs for all my devices every week. For some devices, I haven't the latest version in Config Version Tree in the Config Editor. Is that normal? Maybe because the device wasn't modified since the last backup?
Thanks.
Hi seb,
the config version tree will show you the Latest Config the last time you have made chnages in the config..
Or you can say : as soon as you made any chnages ,you will get a new config in the version tree with that Date.
Afroj
