SYSLOG Cisco Prime LMS
mhuaynate
Hi friends,
I have a question about my syslog from Cisco Prime LMS 4.1, the hours from this syslog in the LMS is diferent from my switch log.  I dont kown why.. I verified the hours betewen switch y the Cisco Prime is the same(the LMS is over Windows Server 2008R2) . both are the same log but in diferent hours about 5 hours.
maybe I have to configure the hours for Syslog in the Cisco Prime.
Log from Switch
Log from Cisco Prime LMS
Thank for all my friend.
Best Regards,
Marco Huaynate Ricaldi.
justine.joubran
I am facing the same problem. Did you get this issue fixed?
Thank you,
Justine.
If you have LMS, i am not sure, but if you have PI 1.2. Take a look at my post.
Basically, syslog feature doesn't work well. I could see couple of syslog through event / alarm, but syslog itself is not working properly.
https://supportforums.cisco.com/message/3861981#3861981
