Track interface state in IOS XE
Lasha Lomjaria
I would like to configure event manager with interface state tracking. When certain interface state changes to "down" I want to automatically shutdown the interface.
I have script that does this but on IOS. IOS XE doesn't have "event track 55 state down" command.
track 55 interface Twe2/0/16 line-protocol
event manager applet Shutdown_Twe2/0/16
action 1.0 syslog msg "Shutting Down Twe2/0/16 - Reason: Line Protocol Down"
action 2.0 cli command "enable"
action 3.0 cli command "config t"
action 4.0 cli command "interface Twe2/0/16"
action 5.0 cli command "shut"
action 6.0 cli command "end"
action 7.0 syslog msg "Shutdown_Twe2/0/16 script ran successfully"
any recommendations how to do this?
the easiest would probably be to just match on syslog pattern instead of tracking:
event syslog pattern "%LINEPROTO-5-UPDOWN: Line protocol on Interface TwentyGigabitEthernet2/0/16, changed state to down"
action 1.0 cli command "enable"
action 2.0 syslog msg "Shutting Down Twe2/0/16 - Reason: Line Protocol Down"
6 Replies 6
balaji.bandi
what  version of IOS XE ?
is this possible to use track global config.  - is this works for you ?
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/xe-17/eem-xe-17-book/eem-policy-cli.html#GUID-104E218A-4DC3-44B8-9653-E5D863FD9643
BB
Thanks for the reply!
Version: IOS XE 16.12.3a
In global config it is possible to use "track 55 interface TwentyFiveGigE2/0/16 line-protocol" command. I have already configured it.
But after that you have to define which object to use for event to occur:
1. configured event manager applet:
2. Tried to configure event tracking, but I get error, because there is no such command in IOS XE:
HQ-Core(config-applet)#event track 55 state down
% Invalid input detected at '^' marker.
They changed  how to do it:
SUMMARY STEPS
• enable
• configure terminal
• track object-number stub-object
• default-state {up | down }
• exit
• event manager applet applet-name
• event [label ] track object-number [state {up | down | any }]
• action label track set object-number state {up | down }
• action label track read object-number
• end
• show track [object-number [brief ]
“event track” in event manager doesn’t exist, which is what the OP said, so this wouldn’t work.
Thank you! It Worked
