URN_NOT_FOUND : urn "JRM" : Not found !!
andylee1892
Hi All,
Running RME 4.0.6; when I navigate to "Config Mgmt > Archive Mgmt > Archive Mgmt Jobs" I get a pop up with the error
I also get a very similar (but slightly different) error when I navigate to "Config Mgmt > NetConfig > NetConfig Jobs"
Error occured while processing.
Possible Cause:
I get similar errors throughout the RME section of Ciscoworks.  Prior to getting this, the CiscoWorks Daemon Manager service was restarted; I have since restarted all CiscoWorks services, however the error persists.
Does anybody have any suggestions?  I have followed this thread -
https://supportforums.cisco.com/thread/2002770
- however it has not resolved the issue.
Thanks in advance for any replies
2 Accepted Solutions
Vinod Arya
Please try to remove ctmregistry and ctmregistry.backup NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib (remove them to any other directory like desktop for backup) and restart daemon manager.
Check the process after that if that works, if not, please share the output of pdshow from server (NMSROOT\bin\pdshow).
FYI, LMS 2.6 is no more supported, being EOS/EOL, all t/shooting will be on a best support basis.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Sorry there is no free upgrade available as such. Next release after LMS 2.x was LMS 3.x, which too is almost end of sale and hence options are now for LMS 4.x, aka, Cisco Prime Central.
You can try though, with your accounts team/Account Manager, if your SmartNet/SAS contract can make you eligible for getting a free upgrade license for LMS 3.x.
If you have the contract number covering your existing LMS, you can check it here as well :
http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
-Thanks
Vinod Arya
-Thanks
Vinod,
Thanks for the reply.  I have restarted the server and it is now all working.  In regard to 2.6 going EoL; do you know if we can upgrade for free, or will we require another license?
Thanks again for your time
Andy
Message was edited by: Andy Lee - Typo!
-Thanks
Vinod,
Thanks again, you have been more than helpful
