vlan sg220
kiko1122
I have 4 vlans (for example vlan 2 - port 2 and 14, 3 and 15.4 and 16, 5 and 17)
how do i configure another port to see these vlans through a web browser
marce1000
 - Your question is unclear , a port is one vlan (simplified) , for more info check this guide :
      https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb80-vlan-configuration-on-the-200-300-series-managed-switches.html
 M.
i want one port to connect to and i see only 4 vlan nothing else that is connected in the switch
it is possible?
i am absolute beginner
thanks
balaji.bandi
you do not want the port need to connect 4 VLAN, and nothing else ? is this correct ?
you can create another VLAN and add to port and make ACL to only view 4 VLAN
BB
