10-04-2020 01:25 AM
I have 4 vlans (for example vlan 2 - port 2 and 14, 3 and 15.4 and 16, 5 and 17)
how do i configure another port to see these vlans through a web browser
10-04-2020 02:29 AM
- Your question is unclear , a port is one vlan (simplified) , for more info check this guide :
M.
10-04-2020 02:47 AM
i want one port to connect to and i see only 4 vlan nothing else that is connected in the switch
it is possible?
i am absolute beginner
thanks
10-04-2020 05:43 AM
you do not want the port need to connect 4 VLAN, and nothing else ? is this correct ?
you can create another VLAN and add to port and make ACL to only view 4 VLAN
