VLANs in " sh VLAN " and running config to not match
JohnW63
Beginner
Beginner
When I run the " sh VLAN  " the command which shows the VLANs what is active and what it is described does not match what the "sh run" command shows me as defined. I have one VLAN in the " sh VLAN " command that doesn't even exist in the running config.
How does this happen ? How does the one not even defined in the running config work at all ?
I think it would be helpful in this conversation to remember the differences between the layer 2 aspect of vlans and the layer 3 aspect of vlans. Essentially a vlan must operate as a layer 2 entity and might also operate as a layer 3 entity. Our familiar definition of vlan as defining a broadcast domain is the layer 2 definition of vlan. The layer 2 vlan information can be propagated by vtp and the layer 2 vlan information is what you see in the vlan data base. The layer 3 aspect of the vlan is defined in the interface vlan x command in running config rather than in vlan.dat.  There is not any requirement that the layer 2 vlan data base be in sync with the layer 3 running config. It is quite legitimate for a vlan to exist in the vlan data base but to have no IP address. And it is quite legitimate for a layer 2 vlan to be active while its layer 3 interface is shutdown.
Rick
20 Replies 20
marce1000
 - It can be present in vlan.dat as of learned for instance if you are you using VTP. It implies for instance that you may not use all the vlans available to your switch in the running-config.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Since we do not know much about your environment
Please provide the device model and what IOS code running
post output below to understand better :
show version
show vlan and dir flash:/
BB
Cristian Matei
    Unless you manually configured VTP, you still run VTP in server mode. If you run VTP in server or client mode, configured VLAN's are kept in the VLAN.dat file in flash and not in the "running-config". If you want to see the VLANs in "running-config", change over to VTP transparent "vtp mode transparent" and you'll see it in "show run".
Cristian Matei.
The switch is our core 9500 in our Data Center, so . I thought it was in server mode. Turns out it's in Client mode.  I don't want it to be in transparent mode. Is there a way to see the VLAN details in the VLAN.dat file ? " sh vlan detail " or something ? I want to confirm what vlan numbers are in use and what IP settings each has before I change a \21 subnet into eight \24 subnets.  It is rather annoying that the running config is not accurate.
if it is client mode all the VLAN information coming from VTP Server. So you need to look at VTP Server see what VLAN available, why it was not populated to Client
check the config on VTP Server and VTP client config. they able to communicate each other.
Most of the Dc environment - suggest to not to deploy VTP Mode, always suggest to have Transparent mode.
post show vtp status along with config.
BB
Normally, our our MDF switch at all of our school sites is the VTP server and all the IDF switches are in client mode. Given this is the core switch in our data center, I don't think we have a VTP " server " in the room.
I looked at the content of the VLAN.dat file, and while is is not directly a text file I could see the VLAN names in the output in the right side column.  How does the VLAN.dat file get it's data ? I would have thought it would be when you create VLANs in the CLI on the switch.
In VTP transparent mode, my running config shows this, now:
vlan 90
name Guest-Wireless-90
vlan 126
name VoIP-2
vlan 231
name UCS-MGMT
vlan 232
name VMware-MGMT
vlan 233
name VM-Motion
vlan 235
name Server_LAN
vlan 500
name INTERNET
vlan 501
name FIREWALL-Deprecated
vlan 502
name FIREWALL-DMZ
vlan 505
name Untrusted
vlan 506
name FIREWALL-INSIDE
vlan 600
name PRIVATE
vlan 999
But the running config lines for the VLANs is this:
interface Vlan1
ip address 10.12.119.254 255.255.248.0
interface Vlan42
no ip address
ip helper-address 10.12.112.1
shutdown
interface Vlan43
no ip address
shutdown
interface Vlan44
no ip address
shutdown
interface Vlan45
no ip address
shutdown
interface Vlan46
no ip address
shutdown
interface Vlan48
no ip address
shutdown
interface Vlan49
no ip address
shutdown
interface Vlan61
no ip address
shutdown
interface Vlan71
no ip address
shutdown
interface Vlan72
no ip address
shutdown
interface Vlan73
no ip address
shutdown
interface Vlan80
no ip address
shutdown
interface Vlan81
no ip address
shutdown
interface Vlan82
no ip address
no ip redirects
shutdown
interface Vlan90
ip address 10.15.240.254 255.255.255.0
ip helper-address 10.12.112.7
ip access-group Guest-Wireless in
interface Vlan125
no ip address
shutdown
interface Vlan126
description VoIP-2
ip address 10.14.222.254 255.255.255.0
ip helper-address 10.12.112.200
interface Vlan200
ip address 10.1.246.230 255.255.255.248
shutdown
interface Vlan231
description UCS Blade and server Management VLAN
ip address 172.30.1.254 255.255.255.0
interface Vlan232
description VM Management VLAN
ip address 172.30.2.254 255.255.255.0
interface Vlan233
no ip address
interface Vlan235
description Server Communication VLAN
ip address 172.30.5.254 255.255.255.0
no ip redirects
interface Vlan310
no ip address
shutdown
interface Vlan500
ip address 163.150.103.254 255.255.255.0
shutdown
interface Vlan501
no ip address
shutdown
interface Vlan505
description Firewall-Inside
ip address 10.12.0.1 255.255.255.0
interface Vlan506
description Depricated Firewall inside
no ip address
shutdown
My concern and confusion comes from VLAN 233 shows active in the "sh vlan" list, but has no IP address in the running config. VLANS 500 and 501 show active in the VLAN command and are shut down in the running config. VLAN 502 shows active in the VLAN command but doesn't exist in the running config. VLAN 506 shows active in the VLAN command but has no IP address in the config. VLAN 600 shows in the VLAN command output, but does not exist in the running config.
This makes configuring the switch for new subnets and VLANs rather unclear.
     You see the VLAN database in two ways:
               - readable format via "show vlan" and "show vtp status" and "show vtp password", as all of these are contained in the VLAN.dat file
              - less readable format by copying it to a remote FTP/TFTP server and reading it as text, or via "more flash:/vlan.dat"
Yes, in the DC, VTP is considered vulnerability (nobody wants a complete DC blackout due to VLANs missing) and it's not used.
Cristian Matei.
Good info, Christian.
But... How do I reconcile what VLANs are actually on the switch and what their IPs are if the running config and the VLAN.dat don't seem to agree ?  How do they get out of synch ? Since we don't have a VTP "server" switch in the Data Center, nothing should be able to over ride the settings in the running config.
Rick
Richard,
If I can submit a follow-up question...
 I started looking up the difference between the two aspects ( layer 2 vs layer 3 ) and I found a recent post of yours, here:
https://community.cisco.com/t5/switching/what-is-layer-2-and-layer-3-vlan/td-p/2921946
In the above thread, you mentioned that VLANs are actually just a layer two feature and that the layer 3 is an interface feature. At least that's how I interpreted it. In the switches I've been studying and using in our network, all the Vlans had a subnet associated with it, which is why finding vlans with no IP perplexed me.  Do you have a good reference doc I can check out to help clear this up for me ?  I'm not sure how I could even utilize a layer 2 Vlan, since I'm used to assigning interfaces to it.
While you were submitting your follow up question I was submitting more explanation, which I hope was helpful. Now let me try to address your follow up question. I am glad that you found that other discussion of layer 2 and 3 vlans. And it is another opportunity to recognize that sometimes we are precise in our terminology and sometimes we are not precise. If we are going to be precise we should say that a vlan is a layer 2 entity (and on many switches it shows up in the vlan database not necessarily in the running config). But a lot of the time our discussions are not so precise and we talk about vlan interfaces which provide layer 3 functionality for the layer 2 vlan. So for many of our discussion the difference is blurred and we talk and act as if a vlan was both layer 2 and layer 3. In your follow up you said "and that the layer 3 is an interface feature. At least that's how I interpreted it." I would say that your interpretation was correct, if we are going to be precise.
In many of our networks when we deploy switches we want them to do both layer 2 and layer 3 forwarding. But in some networks (especially larger networks) we might deploy some switches to do only layer 2 forwarding (like access switches in the network) while layer 3 forwarding is done on the distribution or core layer switches. If we look at earlier models of Cisco switches there were some switches which only had layer 2 forwarding capability - and they were less expensive than the layer 3 switches. In current generations of Cisco switches it is not so common to find switches which are limited to only layer 2 forwarding.
Let me describe a situation which might help you understand why you might want to have some vlans with vlan interfaces processing both layer 2 and 3 and other vlans processing only layer 2. I worked with a customer who had a site with multiple buildings. There was a switch per building. The link between the switches was a trunk which carried multiple vlans. Several vlans carried traffic for user PCs, or servers, etc and one vlan carried traffic for some other devices. These devices needed access to the Internet but needed to be separated from the user and server subnet traffic. The solution was that the switches in each building had vlan interfaces to provide layer 3 services for users and servers etc but the vlan for these other devices did not have vlan interface. So the switches did routing between the subnets for users, servers, etc but not for devices in the restricted vlan. Traffic in the restricted vlan reached the core switch that connected that vlan to a firewall which had security policies that allows those restricted devices to access the Internet but kept them separate from all user and server traffic.
Rick
    In order for the switch to perform the "switch" functionality, a layer2 OSI function, it needs nothing but cables plugged. Having VLAN's, was a first method, back in the old days, to limit the broadcast domain and perform a form of segmentation between devices; so, you had the option to create VLANs and put devices in separate VLAN's; inter-VLAN communication requires a layer 3 device,a  router.
   In order for the switch, which is multilayer switch (Spans its functionality across multiple OSI layers), to perform the "routing" function, and specifically in this case "inter-vlan routing", you add one SVI for each of the VLAN's you want the switch to a act as a default gateway, so to perform layer 3 functions, routing. This is not necessary, and if you do it, you do it only for VLAN's the you need. Other VLAN's can have a default gateway pointing to another layer 3 device (thus your switch has only the VLAN defined, no SVI, it does just switching), or can have no default gateway (which means no communication outside the VLAN).
Cristian Matei.
Thank you !
I hadn't seen stuff on just layer 2 VLANs. All the videos and docs just had simple " How to create VLANs ". So, if I have both layer 2 and layer 3 Vlans, I'll have to look up the reasons why you would use one vs the other.  I then would think that what I am about to do, in changing a large network into 8 sub networks, won't matter to the devices in the layer 2 Vlans.  I just don't want to break our network because I didn't understand all the routing.
