Bookmark
Subscribe
1068
WAN Interface with an OperStatus of "TESTING"
lchance
can anyone explain how a wan circuit can go from 'up' to a state of 'testing'? i don't think this is done through the ios, such as admindown, is it?
can the carrier/provider place the circuit in this state?
here's some oid/mib info:
Object
ifOperStatus
OID
1.3.6.1.2.1.2.2.1.8
Type
INTEGER
Permission
read-only
Status
current
Values
1 : up
2 : down
3 : testing
4 : unknown
5 : dormant
6 : notPresent
7 : lowerLayerDown
MIB
IF-MIB ; - View Supporting Images
Description
"The current operational state of the interface. The
testing(3) state indicates that no operational packets can
be passed. If ifAdminStatus is down(2) then ifOperStatus
should be down(2). If ifAdminStatus is changed to up(1)
then ifOperStatus should change to up(1) if the interface is
ready to transmit and receive network traffic; it should
change to dormant(5) if the interface is waiting for
external actions (such as a serial line waiting for an
incoming connection); it should remain in the down(2) state
if and only if there is a fault that prevents it from going
to the up(1) state; it should remain in the notPresent(6)
state if the interface has missing (typically, hardware)
components."
thanks,
lc
Joe Clarke
If the interface is placed in a loopback, then its OperStatus will be testing. The provider or you may have looped the interface for diagnostic purposes.
