WEB FILTERING
oyenibi4lv
Hi all,
I have a 3845 cisco router, i need to block access to sites such as facebook, youtube on the router itself while allowing the executive to have access to these sites. I dont have a firewall for now, can this be achieved on the router. command line will be appreciated. 192.168.20.0 is y LAN ip.
zdesignstudio
Level 4
Level 4
Here is a decent how-to.
http://www.techrepublic.com/article/block-access-to-a-web-site-using-the-cisco-ios/
Please rate useful posts and mark answers as correct if applicable.
Kias
As its HTTPS inpection, you need to integrate a content filter of cisco or other vendors. Also you could build your open source squid-cache proxy and intercept SSL traffic on physical or virtual machine. This helps you to customise URL blocking policies for HTTP and HTTPs sites. The machine is connected via WCCP to the router.
Kias
Fonicom Limited
raiseaticket Malta
Mark Elsen
  - Whilst a valid request , in the IoT age, the problem becomes 'broadened' and may need a wider philosopy approach. For instance ; we don't block facebook , because it would probably need to a 30% company productivity loss, as people would perhaps be more watching their smartphone then their PC. In that context, additional solutions can be implemented related to MDM enforcing products :
https://en.wikipedia.org/wiki/Mobile_device_management
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
