03-13-2013 08:10 PM
What is the relation between:
As i orderd a Cisco Prime infrastructure from a Cisco Partner and what i got is :
x2 cisco NCS appliances
x1 DVD cisco prime infrastructure
x1 DVD Cisco prime 4.2
Don't know what to do ... and which is installed on which device !! any thoughts ??
Solved! Go to Solution.
03-13-2013 09:05 PM
Prime Infrastructure has for the most part replaced NCS as Cisco's wireless (and, to some extent, wired) infrastructure management tool. NCS is still being updated (1.1.3.2 dated 7 Feb 2013) but only incrementally. Most development work is focused on the flagship PI product.
Along the way, Prime Infrastructure (currently at version 1.3) has acquired wired infrastructure management (among other things) but has not yet reached parity with Cisco Prime LMS. The roadmap is targeting much greater (but not complete) feature parity with LMS when PI 2.0 is released later this year.
Prime LMS (current release is 4.2.3) is the sucessor to Cisco LMS / CiscoWorks LMS and RWAN / CiscoWorks 2000 / CWSI / CiscoWorks etc. It is the most full-featured product for Cisco wired infrastructure.
So, back to your question. Build one appliance with PI 1.3, the other with LMS 4.2 (patched to 4.2.3). Focus on following up that technology upgrade with process and people development / adaptation. Watch for PI 2.0 to make an informed choice as to whether it is time to replace LMS altogether. (I remain hopeful yet doubtful on this last point.)
03-13-2013 09:05 PM
03-14-2013 03:40 PM
Thanks Marvin so much
can you point me to a doc. or a whitepaper on how to install the LMS4.2 or PI 1.3 (DVD) on the NCS appliance ...that woud be greate
Thanks again
Michael
03-14-2013 07:09 PM
You're welcome.
Hmmm - upgrading NCS appliance to LMS 4.2 - I haven't come across any way to do that. Not sure there is a supported or documented path on how to. Frankly, why would you want to?
You can move from NCS on appliance to PI 1.3 on the same appliance. Follow this procedure.
03-14-2013 07:52 PM
Marvin,
I just booted from the DVD and the PI is now installed on the NCS and on the way to install LMS 4.2 on the other appliance ... Thanks a lot for you help
