03-13-2021 05:18 AM
The interface is still showing up/up in my router when I am unable to ping the ISP PE router.
The keepalive setting is the default of 10sec, so I would assume the interface would be up/down when the ISP PE router is down?
This Ethernet interface is connected to a ISP PE router with the following settings:
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
delay 5000
duplex full
speed 100
media-type rj45
Keepalive set (10 sec)
03-13-2021 06:11 AM
The most case you connect to NTU, it never goes down - so the connected interface always up/up (depends on the provider) so check the CDP neighbor you can see the PE router.
what kind of circuit delivery?
post the interface status
show interface gi0/0
03-13-2021 07:36 AM
Ah, NTU will always be up? I will check on cdp neighbor when possible.
Show interface:
Hardware is iGbE, address is
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100000 usec,
Full Duplex, 100Mbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Queueing strategy: fifo
Output queue: 0/40 (size/max)
03-14-2021 07:12 AM
this output does not show up/up? post complete show interface gi 0/0 -what device is this?
03-14-2021 07:50 AM
It is the same Ethernet interface, just that I missed out the up/up and removed IP addresses for security reasons.
GigabitEthernet0/1 is up, line protocol is up
Internet address is
Last input 1y3w, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w3d
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
410518 packets output, 54818378 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
03-14-2021 11:15 AM
-what device is this? can you post-show version?
what is the outcome if you remove the cable from Gi 0/1 ? is the interface still up?
03-14-2021 05:38 PM
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9
8 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
I am unable to remove the cable as the device is at a remote site.
03-15-2021 03:11 AM
Looks it connect to NTU so i believe that is the reason this up all time, but it did not have any traffic for long. as provider to test NTU off the port and check.
03-14-2021 06:34 AM
Verified that the ISP PE router or NTU is not showing up as a CDP neighbor.
03-13-2021 06:32 AM
Are you use ISP PE as L2 or L3VPN ?
03-13-2021 07:39 AM
L3VPN.
03-14-2021 04:03 PM
the only reason there is L2 between CE and PE and this make the link UP/UP.
03-14-2021 05:39 PM
What would be a possible L2 between the CE & PE? Thanks!
