Why is this Ethernet interface up/up ?
rakuten02
The interface is still showing up/up in my router when I am unable to ping the ISP PE router.
The keepalive setting is the default of 10sec, so I would assume the interface would be up/down when the ISP PE router is down?
This Ethernet interface is connected to a ISP PE router with the following settings:
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
delay 5000
duplex full
speed 100
media-type rj45
Keepalive set (10 sec)
12 Replies 12
balaji.bandi
The most case you connect to NTU, it never goes down - so the connected interface always up/up (depends on the provider) so check the CDP neighbor you can see the PE router.
what kind of circuit delivery?
post the interface status
show interface gi0/0
BB
Ah, NTU will always be up? I will check on cdp neighbor when possible.
Show interface:
Hardware is iGbE, address is
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100000 usec,
Full Duplex, 100Mbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Queueing strategy: fifo
Output queue: 0/40 (size/max)
this output does not show up/up? post complete show interface gi 0/0  -what device is this?
BB
It is the same Ethernet interface, just that I missed out the up/up and removed IP addresses for security reasons.
GigabitEthernet0/1 is up, line protocol is up
Internet address is
Last input 1y3w, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w3d
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
410518 packets output, 54818378 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
-what device is this?  can you post-show version?
what is the outcome if you remove the cable from Gi 0/1 ? is the interface still up?
BB
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9
8 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
I am unable to remove the cable as the device is at a remote site.
Looks it connect to NTU so i believe that is the reason this up all time, but it did not have any traffic for long. as provider to test NTU off the port and check.
BB
Verified that the ISP PE router or NTU is not showing up as a CDP neighbor.
Are you use ISP PE as L2 or L3VPN ?
L3VPN.
the only reason there is L2 between CE and PE and this make the link UP/UP.
What would be a possible L2 between the CE & PE? Thanks!
