WLC
georgeef1
Level 4
Level 4
I have WLC and it is not coming green on the topology service when the
SNMP v2 or v3 is enabled. But it shows green when I enable SNMP v1 on it.
How can we set SNMP v2 or v3 on WLC to have the device come green in Topology as well?
-Thanks
Joe Clarke
You must enable SNMPv1 on the WLC. That is required to manage it if you are using community string-based SNMP. LMS 3.2 has converted to mostly using SNMPv2c, and only falling back to v1 if absolutely necessary.
Thanks Jclarke,
One last question, if I upgrade to LMS 3.2 can I use the SNMP v2 option on my WLC?
-Thanks
Yes.
