06-30-2022 11:56 PM
Hi Team
I have WS-C3850-24T (None POe) switch with Default AC power supply PWR-C1-350WAC i want to install secondary supply in it as its an critical switch.
I have a spare of PWR-C1-715WAC-P V01 can i use this power supply as secondary into the same switch with primary PWR-C1-350WAC or we need same power supply model for both primary and secondary slot.
Thanks in advance
07-01-2022 12:13 AM
sure check installation guide :
07-01-2022 12:13 AM
Yes, it is fine.
07-01-2022 12:17 AM
yes you can mix PWR-C1-350WAC with PWR-C1-715WAC-P V01
