ASDM Not Running
fatalXerror
Level 5
Level 5
Hi guys, I have a new FP2130 running in ASA code and I did all necessary config already for accessing the ASA via ssh and http using ASDM.
SSH is working however, ASDM is not.
When I open my ASDM and entering the username and password, the ASDM will just load then it will close then nothing happens.
any idea how to resolve this?
thanks
balaji.bandi
what is the version of ASA and ASDM?
check the matrix :
https://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html
BB
run the ASDM using CLI which will show the error messages if any.
Good luck
KB
Sheraz.Salim
this is most probably due to a file called .jar  (Java) you need to make sure your ASA software is compitable with ASDM file.
please do not forget to rate.
I would try to enable the http and asdm debugs and see if they return any clear output to helping tshooting the issue.
debug http 127
debug asdm history 255
