Cisco Asa Port Forwarding using a custom RDP Port
Frederic Garcia
I need to translate a custom RDP Port. I'm a little bit stuck...
 Here the rules :
object network RDP-Server
 nat (inside,outside) static interface service tcp 3389 33890
access-list outside_access_in extended permit object RDP-Service any object RDP-Server
RDP-Service = 3389
RDP-Service-Ext 33890
Thanks for your help ! :)
8 Replies 8
Try to add a permit ip any any in the acl just for test.
If it works try
access-list outside_access_in extended permit tcp any host YOUR SERVER IP eq 3389
Regards.
Hello Daniele,
Thanks for your help.
Your command has been accepted by my Cisco Asa. I think it was ok because my Hits are ok.
My Asa Version si 9.6(2)22
You will find in attachment a screenshot of my NAT config with the VPN.
Do you have tested the port forward? I see hits on your screenshot.
Regards.
What did you mean for tested my port forward ?
I try to connect with a laptop using a 4G, and i have a error. And I'm ok with you, I see the hits on my screenshot after each try.
1) if you temporarilly add a permit ip any any to acl, are you abel to connect to your server?
If yes, the problem is in the ACL
If no the problem could be in your server
2) Are you able to connect to your server using private IP?
if yes the problem is on the ASA
if no the problme is in the server
Let me know your findings.
Regards.
ok !
With an internal IP it's OK.
If I use my VPN it's OK.
But, We have a external ressource to help us on the ERP. We prefer a RDP connection than VPN.
So, the server is configured correctly.
Can you try to modify temporarily the access list and permit all just for test?
If the RDP connection works, the issue is in the ACL.
If it doesn't work the issue is in the NAT.
Regards.
It's doesn't work.
Here the conf of my all NAT rules.
nat (inside,outside) source static NETWORK-PROGINOV2 NETWORK-PROGINOV2 destination static NETWORK-ANYCONNECT NETWORK-ANYCONNECT no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK-PROGINOV NETWORK-PROGINOV destination static NETWORK-ANYCONNECT NETWORK-ANYCONNECT no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK-INSIDE NETWORK-INSIDE destination static NETWORK-ANYCONNECT NETWORK-ANYCONNECT no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK-BSM NETWORK-BSM destination static NETWORK-ANYCONNECT NETWORK-ANYCONNECT no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK-LORIENT NETWORK-LORIENT destination static NETWORK-ANYCONNECT NETWORK-ANYCONNECT no-proxy-arp route-lookup
object network NETWORK-INSIDE
 nat (inside,outside) dynamic interface
object network Theseus
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
