Cisco ASA5510 Clientless webportal problem
danhed7400
hi.
i have a strange problem.
i have Redundant ASA5510 setup (active/passive)
users have been using IPsec and SSL vpn for a long time without any problem.
now some users want to be able to access bookmarks and company data through the Web portal.
i have enabled Clientless SSL VPN Access, and created a Connection profile, with clientless SSL VPN protocol enabled
when i access to outside of the ASA, im promtet for login, and after succesful login, it starts to download and install the Anyconnect client. and the portal never appers, i have change the option "default post login selection" to go to clientless SSL VPN portal, but i has no effect.
what am im missing ??, i have enabled the service before on other ASA firewall, without any problem, as i recall there`s no need for additional software on the ASA.
i have tried to manuel change the url to https://Domain.domain.dk/+CSCOE+/portal.html , after a succesful login, but it auto changes to
https://Domain.domain.dk/+CSCOE+/noportal.html
6 Replies 6
danhed7400
no comment on this ?
RonJaws4-CTP
Hopefully you have figured this out by now, its been a few months. I had the same problem. You must disable anyconnect essentials in order to use Clientless VPN. I recommend checking with TAC on your license situation first and also testing to ensure both clientless and client vpn work after you make the change. See the screenshot below.
I hope this helps
Hi Ron,
hi Dan,
I still run into the same problem after adding an AnyConnect Premium Peer License to an ASA which still have
AnyConnect Essentials License.
After configuring clientless vpn I run into the first issue: after successfully login with clientless vpn the anyconnect client downloader starts automatically every time. No matter that in every group-policy the 'Post Login Settings' are configured to 'Go to Clientless SSL VPN portal'.
I spent hours in troublehshooting and nothing helps. Even deleting all group-policies, tunnel-groups and webvpn configuration making the complete configuration step-by-step again is leading into the same problem.
Only when I toggle the 'Post Login Settings' to 'Prompt user to choose' I got the same issue as Dan:
Empty page on https://Domain.domain.de/+CSCOE+/portal.html
Then I found this thread and Rons answer. After disabling anyconnect essentials as Ron wrote the clientless vpn is working.
Many Thanks!
Michael
dear sir
i need help with the clientless web vpn configuration through ASA 5520 with 7.2
I've  done all the configuration on the asa and everything is working but  still a problem with the port-forwarding which is on the client side the  java don't wont to accept the certificate  is there a solution for this  problem
actually my goal for configuring the clientless webvpn is to allow telnet and remote desktop sessions
hope there is an answer
fturner94
This is mainly for anyone who stumbles upon this now since it was never answered. I had this issue recently and after verifying "http server enable" was set, "Encryption-3DES-AES" was Enabled (show version) and I had access available from the subnet I was trying to access it from, I just changed the path to include the "/admin", (so https://x.x.x.x/admin) option and it allowed me to access the ASA.
I was just attempting to get to the web browser to download ASDM and ran into this, so hopefully this helps anyone doing a frantic google search!
alain.riesen
there might be a simple solution to this. It might be, that in the WebVPN configuration the secure client (anyconnect) image is missing.
Adding it with "anyconnect image flash:/<image>.pkg 1" did solve the problem for me.
