Bookmark
Subscribe
1972
Problem with SSL inspection in FTD
ahmadtec9
Hello everyone
I have a weird problem with configuring SSL inspection In Cisco FTD , every time I enable SSL policy In ACP  all ssh session that go through FTD will be drop after 10 to 20 seconds .
even configuring  all SSL Rule to do not decrypt still have the problem !
also I select "inherit Default Action" in  Undecryptable encryption tab which is do not Decrypt.
thanks
5 Replies 5
Marvin Rhoads
Generally an SSL decryption policy should apply to SSL traffic which is specified via a combination of the application ("SSL"), port (tcp/443) and address sections of the rule(s). Can you share more details on how you have yours configured?
At the beginning I define a simple rule like :
src-zone=inside  dst-zone= outside    network=my-pc     action >>> Decrypt-Resign
Default action : do not decrypt
After Enable SSL policy in ACP all SSH traffic  from any zone to other  zone  Will be drop .
after getting problem define a rule at the top of SSL Policy to do not decrypt any packet that dst-port=22
but nothing change !
balaji.bandi
SSL policy should use port 443, SSH uses  port 22, so there may be something missing in the ACP.
BB
Before applying SSL policy to ACP everything is fine and there is no problem with ssh Connection.
I'm not sure, but is there any possibility that  SSH use some sort of TLS protocol that ssl inspection deny it ?
Your SSL policy should be built so that it ONLY selects SSL traffic.
i.e., make the application "SSL Client" and the destination port HTTPS.
