MST Configuration
RS19
Level 4
Level 4
I have Cisco 2960 switch & I am going to use MST for spanning tree
Below is the configuration
spanning-tree mst configuration
 name TEST-MST
 revision 1
 instance 1 vlan 101
 instance 1 vlan 102
I have 2 VLANS & I want to add both the VLANs into instance 1.
There will be only 1 instance.
Would like to know, technically if this is possible.
6 Replies 6
Marvel
Hi RS19,
Technically, 2 VLANs can be configured on Instance 1 and they can be verified as well.
RS19
Level 4
Level 4
Thanks.
But I will not be configuring or using any VLANs in Instance 2.
Only VLANs in instance 1. No instance 2 will be used.
My understanding it should be fine.
Marvelleous
Yes, indeed.
Marvelleous
Marvel
Hi @RS19,
You can do configuration like this:
SW>enable SW#configure terminal SW(config)#spanning-tree mode mst SW(config)#spanning-tree mst configuration SW(config-mst)#revision 1 SW(config-mst)#name TEST-MST SW(config-mst)#instance 1 vlan 101, 102 SW(config-mst)#exit SW(config)#spanning-tree mst 1 priority 16384 SW(config)#end
SW#show spanning-tree mst 1
##### MST1    vlans mapped:   101,102
Bridge        address 0014.a964.2e00  priority      32769 (32768 sysid 1)
Root          address 0014.f2d2.4180  priority      16384  (8192 sysid 1)
              port    Fa0/10          cost          200000    rem hops 19
Deepak Kumar
Yes, it is possible and this is the default behavior of the MST (run Single instant of STP for multiple VLANs). If this switch is in the production then my recommendation for migration step by step as like:
1. Configure MST configuration on all switches.
  revision 1
  name TEST-MST
2. Decide a Root bridge as per your network topology, hardware resources, etc. (take care of PVST simulation)
 spanning-tree mst 1 priority 4096/0 <Priority as per your network configuration>
3. now migrate from PVTS to MST
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
