szeya
Hosting Native Docker Container on C9300
Powered by an x86 CPU, the application hosting solution on the Cisco® Catalyst® 9000 series switches provide the intelligence required at the edge. This gives administrators a platform for leveraging their own tools and utilities, such as a security agent, Internet of Things (IoT) sensor, and traffic monitoring agent.
Application hosting on Cisco Catalyst 9000 family switches opens up new opportunities for innovation by converging network connectivity with a distributed application runtime environment, including hosting applications developed by partners and developers.
Cisco IOS XE 16.12.1 introduced native Docker container support on Catalyst 9300 series switches. Now, C9404 and C9407 models also can support Docker container with Cisco IOS XE 17.1.1 release.  This enables users to build and bring their own applications without additional packaging. Developers don’t have to reinvent the wheel by rewriting the applications every time there is an infrastructure change. Once packaged within Docker, the applications will work within any infrastructure that supports docker containers.
In this blog, you will see how you can use native docker image (iperf) from Docker Hub to measure network performance by hosting on Cisco Catalyst 9300 switch.
Step-by-step installation configuration
1. Download the iPerf docker image to the local laptop.
Download the latest iPerf image from Docker Hub to the laptop.
Docker engine has to be installed on laptop and can pull iPerf image from Docker Hub.
MyPC$ docker pull mlabbe/iperf3
Save the downloaded iPerf docker image as a tar archive:
MyPC$ docker save mlabbe/iperf3 > iPerf.tar
2. Login to the Catalyst 9300 and copy the iPerf.tar archive to the flash: drive.
copy usbflash0:iPerf.tar flash:
3. Configure network connectivity to the IPerf docker.
a. Create the VLAN and VLAN interface:
      conf t
      interface Vlan123
b. Configure the AppGigabitEthernet1/0/1 interface:
       interface AppGigabitEthernet1/0/1
       switchport mode trunk
The above configuration allows VLAN 123 on the AppGigabitEthernet port.
c. Map vNIC interface eth0 of the IPerf docker to VLAN 123 on the AppGigabitEthernet 1/0/1 interface:
       conf t
       app-hosting appid iPerf
       app-vnic AppGigEthernet trunk
       guest-interface 0
       vlan 123 guest-interface 0
       guest-ipaddress 172.26.123.202 netmask 255.255.255.0
       app-default-gateway 172.26.123.1 guest-interface 0
4. Enable and verify App Hosting.
a. Verify that the USB SSD-120G flash storage is used.
     dir usbflash1:
     Directory of usbflash1:/
    11 drwx           16384    Mar 25 2019 22:32:36 +00:00    lost+found
    118014062592 bytes total (105824313344 bytes free)
Note: SSD-120G will be shown as usbflash1: in IOS-XE CLI. Internal flash and front panel usb (usbflash0:) do not support for application hosting.
b. Configure iox for App Hosting:
 conf t
 iox
show iox-service
IOx Infrastructure Summary:
 IOx service (CAF)      : Running
 IOx service (HA)        : Running
 IOx service (IOxman)  : Running
 Libvirtd                      : Running
 Dockerd                    : Running
5. Install ,activate and run the IPerf docker cat9k application.
a. Deploy the IPerf docker application:
   app-hosting install appid iPerf package flash:iPerf.tar
   Installing package 'flash:iPerf.tar' for iPerf. Use 'show app-hosting list' for progress.
    App id                                   State
    iPerf                                  DEPLOYED
 b. Activate the IPerf docker application:
    app-hosting activate appid iPerf
    iPerf activated successfully
    Current state is: ACTIVATED
c. Start the IPerf docker  application:
    app-hosting start appid iPerf
    iPerf started successfully
    Current state is: RUNNING
d. Verify that the IPerf docker  application is running:
    App id                                   State
     iPerf                                  RUNNING
6. Working with the app.
a. Check app details.
   show app-hosting detail appid iperf
   App id                 : iperf
   Owner                 : iox
   State                   : RUNNING
   Application
   Type                    : docker
   Version                : latest
   Description          :
   Path                 : usbflash0:iperf3_sai.tar
   Activated profile name : custom
   Resource reservation
     Memory              : 2048 MB
     Disk                    : 4000 MB
     CPU                    : 7400 units
     VCPU                  : 1 units
   Attached devices
     Type              Name               Alias
     serial/shell      iox_console_shell   serial0
     serial/aux        iox_console_aux     serial1
     serial/syslog    iox_syslog          serial2
     serial/trace      iox_trace           serial3
   Network interfaces
  eth0:
   MAC address        : 52:54:dd:50:b5:ce
   IPv4 address         : 172.26.123.202
   Network name      : mgmt-bridge193
   Docker
   Run-time information
     Command              :
     Entry-point             : iperf3 -s
     Run options in use  :
   Application health information
     Status                    : 0
     Last probe error     :
     Last probe output   :
b. Check app utilization.
   show app-hosting utilization appid iPerf
   Application: iPerf
   CPU Utilization:
     CPU Allocation: 7400 units
     CPU Used: 1.49 %
   Memory Utilization:
     Memory Allocation: 2048 MB
     Memory Used: 893 KB
  Disk Utilization:
     Disk Allocation: 4000 MB
     Disk Used: 0.00 MB
7. Monitoring performance between the laptop and C9300.
MyPC$ iperf3 -c 172.26.123.202
Connecting to host 172.26.123.202, port 5201
[  5] local 10.154.164.97 port 59408 connected to 172.26.123.202 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  7.51 MBytes  63.0 Mbits/sec
[  5]   1.00-2.00   sec  8.24 MBytes  69.2 Mbits/sec
[  5]   2.00-3.00   sec  10.0 MBytes  84.2 Mbits/sec
[  5]   3.00-4.00   sec  9.52 MBytes  79.9 Mbits/sec
[  5]   4.00-5.00   sec  9.36 MBytes  78.5 Mbits/sec
[  5]   5.00-6.00   sec  10.8 MBytes  90.8 Mbits/sec
[  5]   6.00-7.00   sec  10.1 MBytes  84.9 Mbits/sec
[  5]   7.00-8.00   sec  9.62 MBytes  80.7 Mbits/sec
[  5]   8.00-9.00   sec  10.9 MBytes  91.2 Mbits/sec
[  5]   9.00-10.00  sec  4.51 MBytes  37.7 Mbits/sec
[  5]   0.00-10.00  sec  90.6 MBytes  76.0 Mbits/sec                  sender
[  5]   0.00-10.01  sec  90.1 MBytes  75.5 Mbits/sec                  receiver
21 Comments
Liqun Yang
Very interesting. I assume this will work on other cat9k, such as, 9500 as well, right? Is 16.12.1 is the first release to support this feature?
Leon
szeya
Hi Leon,
9500 support is part of roadmap. Yes, native docker support is starting from IOS XE 16.12.1 release.
NetworkTinker
Hi, thanks for the posting, I believe some of the commands in your posted have now been deprecated and your example will need an update !
I can't exactly work out why these have changed as I was run the version....
Gibraltar-16.12.1 with release dated: Aug 1st 2019
my examples below will also probably be outdated before you know it too. :)
I achieved my testing with two 9300's back to back using the data ports on access vlans on the AppG1/0/1 interfaces but only got it working using DHCP,  I just couldn't seem to get the configuration to work with static addressing
note; all the other groundwork that you've laid down in the above was the same process.
!!same config on both switches
iox
 interface GigabitEthernet1/0/1
 description * DHCP SERVER INTERFACE *
 switchport access vlan 4000
 switchport mode access
interface GigabitEthernet1/0/2
description * BACK TO BACK 9300 *
! interface AppGigabitEthernet1/0/1 description * APP INTERFACE * switchport access vlan 4000 switchport mode access ! interface Vlan4000 ip address dhcp ! app-hosting appid DEMO_IPERF app-vnic AppGigabitEthernet access guest-interface 0
from the CLI
!launch session from container
app-hosting connect appid DEMO_IPERF session
/ $ iperf3 -c 192.168.10.251
Connecting to host 192.168.10.251, port 5201
[ 5] local 192.168.10.252 port 54396 connected to 192.168.10.251 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 116 MBytes 970 Mbits/sec 0 1.58 MBytes
[ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 0 1.58 MBytes
[ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 4.00-5.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 6.00-7.00 sec 111 MBytes 933 Mbits/sec 0 1.58 MBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 8.00-9.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 1.58 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 944 Mbits/sec 0 sender
[ 5] 0.00-10.02 sec 1.10 GBytes 939 Mbits/sec receiver
NetworkTinker
other example i got working was as follows:
This uses the management interfaces on the back of both 9300 switches.
(9300) Gi0/0 ---(generic switch) --- Gi0/0 (9300) Gi0/0
The default settings within iperf3 container is setup as a Server on the switches, so you only need to logon to one switch with app-hosting connect and run  / $ iperf3 -c 192.168.10.251
sho app-hosting detail
! omit
! omit
Docker
Command :
SWI1
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 192.168.10.12 255.255.255.0
 negotiation auto
 app-vnic management guest-interface 0
  guest-ipaddress 192.168.10.252 netmask 255.255.255.0
SWI2
 ip address 192.168.10.11 255.255.255.0
 negotiation auto
! interface AppGigabitEthernet1/0/1 !
app-vnic management guest-interface 0 guest-ipaddress 192.168.10.251 netmask 255.255.255.0
JohnKaftan2984
Is there a way to run IPERF from a Cat 4500?  I assume not as this appears to be all new with the 9000 series.
Thank you
barweiss45
@JohnKaftan2984 Just to answer your question, no the Catalyst 4500 services switches don't use IOS-XE like the Catalyst 9K switches. IOS-XE (>=Denali 16.1.1) uses a x86 architecture and runs IOS as a daemon (IOSd). It has the ability to also run 3rd party applications in as a container using LXC (Linux Containers). That is a very watered down explanation. I found this this FAQ that Cisco released that will help answer some questions of Cisco IOS-XE programmability:
https://www.cisco.com/c/dam/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/q-and-a-c67-737653.pdf
Service containers are applications that can be hosted directly
on Cisco IOS® XE routing platforms. The apps use the Linux
aspects of the IOS XE operating system to host both Linux
Virtual Containers (LXC) and Kernel virtual machines (KVM) on
Cisco 4000 Series Integrated Services Routers (ISR), Cisco
ASR 1000 Series Aggregation Services Routers, and Cisco
Cloud Services Routers 1000V.
For more info, I would checkout the Cisco Live session - Catalyst 9300 Switching Architecture - BRKARC-3863 on www.ciscolive365.com here is the slide deck https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKARC-3863.pdf
I think that answer is yes but app hosting is available on 9300L series? Thank you
szeya
Yes, 9300-L is supported.
_|brt.drml|_
my switch complains that a bunch of files are missing in the iperf3.tar.
Any idea?
package.yaml and many more.
I guess that the docker image or the image created with the docker save command is missing valuable files?
Thanks for the help.
craighowson
Hi all
Could someone please confirm what the guest-ipaddress on the vnic is referring to? Im not sure what the 172.26.123.202 IP address relates to in my network?
       conf t
       guest-interface 0
_|brt.drml|_
That should be the IP address of your 'virtual' host inside the switch.
A virtual host is like a logical computer turning in the switch. It also needs a connection to the network. In this configuration you determine what the IP address and Default Gateway should be. Furthermore, you can also add DNS information.
When you perform:
Guestshell disable, guestshell destroy, guestshell enable.... Then you configure those 'network setting' in the logical device.
You should be aware of your network settings.
I hope this answer helped you.
There are some good cisco life explanations about the subject out there. Be sure to have a look at them.
Good luck
Bart
fabian@zurich
hi Szeya,
I have tried all your Steps, but whenever I try to install, I get an error message:
Cat9300#app-hosting install appid iPerf package usbflash0:iPerf.tar
Installing package 'usbflash0:iPerf.tar' for 'iPerf'. Use 'show app-hosting list' for progress.
Cat9300#Dec 8 2021 09:57:18.559 CET: %IM-6-INSTALL_MSG: Switch 1 R0/0: ioxman: app-hosting: Install failed: App signature validation is enabled. App signature file package.cert or package.sign not found in package
I think, we have all prereq: IOS-XE 17.3.4, DNA-Advantage, the same docker Package as you : mlabbe/iperf3
Any help would be great, Fabian
_|brt.drml|_
Hi there,
You need to build a package yourself. Information can be found.
The error is telling you that key parts of the package are missing.
Do remember that newer ios xe 17 do support the app-hosting via the docker image. On older versions you can only host applications with the USB SSD dongle.
On older IOS XE you need to build / generate the package yourself. [it is not that difficult]
Try google search on package build app-hosting. There are some good Cisco Life session providing good and usable content.
fabian@zurich
as I have mentioned before, we have just followed step-by-step exactly the procedure described in the blog, but we ended up with the errors above.
We dont want to build our own app, because the nice thing about docker is, that a huge base of containers is available. We have also tried different iperf containers, always the same result.
With 17.3.4 the app-hosting is supported.
Best regards, Fabian
jp-networkengr
"In this example, the client was run from a PC so result/log file can be saved rather easy with the run option --logfile <filename>. I tried this option running the client from the iPerf container running from the USB SSD drive (C9500) and can't seem to write/access the file using the same run option?
Does anyone know how to write the result to a file when running iPerf client from a USB SSD drive?"
I have used the -logfile option to write to a file, e.g. iox_data/appdata/test.txt
This file is only accessible when you have a connected session to the app, using the command: app-hosting connect appid iperf session. Then use the cat command to look at the file.
Note: I have tested this when running an iPerf server from a USB SSD drive but am assuming it's the same for the client.
