Edgar c Francis
Route Redistribution configuration
            we have already learned what is route redistribution and why we need, if you don't then click here . In this section we see configuration.
R1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        10.1.1.1        YES manual up                    up
Serial3/0                    1.1.1.1         YES manual up                    up
Serial3/3                    4.1.1.2         YES manual up                    up
Serial3/6                  15.1.1.1        YES manual up                    up
Loopback0              11.0.0.1        YES manual up                    up
Loopback1              11.0.1.1        YES manual up                    up
Loopback2              11.0.2.1        YES manual up                    up
Loopback3              11.0.3.1        YES manual up                    up
R2#show ip interface brief
FastEthernet0/0        20.1.1.1        YES manual up                    up
Serial3/0                    1.1.1.2         YES manual up                    up
Serial3/1                    2.1.1.1         YES manual up                    up
Serial3/4                  24.1.1.1        YES manual up                    up
Loopback0              12.0.0.1        YES manual up                    up
Loopback1              12.0.1.1        YES manual up                    up
Loopback2              12.0.2.1        YES manual up                    up
Loopback3              12.0.3.1        YES manual up                    up
v
R3#show ip interface brief
FastEthernet0/0        30.1.1.1        YES manual up                    up
Serial3/1                    2.1.1.2         YES manual up                    up
Serial3/2                   3.1.1.1         YES manual up                    up
Serial3/5                 35.1.1.1        YES manual up                    up
Loopback0              13.0.0.1        YES manual up                    up
Loopback1              13.0.1.1        YES manual up                    up
Loopback2              13.0.2.1        YES manual up                    up
Loopback3              13.0.3.1        YES manual up                    up
R4#show ip interface brief
FastEthernet0/0        40.1.1.1        YES manual up                    up
Serial3/2                    3.1.1.2         YES manual up                    up
Serial3/3                    4.1.1.1         YES manual up                    up
Serial3/7                  45.1.1.1        YES manual up                    up
Loopback0              14.0.0.1        YES manual up                    up
Loopback1              14.0.1.1        YES manual up                    up
Loopback2              14.0.2.1        YES manual up                    up
Loopback3              14.0.3.1        YES manual up                    up
R5#show ip interface brief
FastEthernet0/0        50.1.1.1        YES manual up                    up
Serial3/4                   24.1.1.2        YES manual up                    up
Serial3/5                   35.1.1.2        YES manual up                    up
Serial3/7                   45.1.1.2        YES manual up                    up
Loopback0              150.0.0.1       YES manual up                    up
Loopback1              150.0.1.1       YES manual up                    up
Loopback2              150.0.2.1       YES manual up                    up
Loopback3              150.0.3.1       YES manual up                    up
R1(config)#router eigrp 210
R1(config-router)#network 1.0.0.0
R1(config-router)#network 10.0.0.0
R1(config-router)#no auto-summary
R1(config-router)#exit
R1(config)#router rip
R1(config-router)#version 2
R1(config-router)#network 15.0.0.0
R1(config-router)#network 11.0.0.0
R1(config)#router eigrp 140
R1(config-router)#network 4.0.0.0
R2(config)#router eigrp 210
R2(config-router)#network 1.0.0.0
R2(config-router)#network 20.0.0.0
R2(config-router)#no auto-summary
R2(config-router)#exit
R2(config)#router rip
R2(config-router)#version 2
R2(config-router)#network 12.0.0.0
R2(config-router)#network 2.0.0.0
R2(config)#router ospf 11
R2(config-router)#network 25.0.0.0 0.255.255.255 area 0
R3(config)#router rip
R3(config-router)#version 2
R3(config-router)#network 2.0.0.0
R3(config-router)#network 13.0.0.0
R3(config-router)#no auto-summary
R3(config-router)#exit
R3(config)#router eigrp 53
R3(config-router)#network 35.0.0.0
R3(config-router)#network 30.0.0.0
R3(config)#router ospf 10
R3(config-router)#network 3.0.0.0 0.255.255.255 area 0
R4(config)#router ospf 10
R4(config-router)#network 3.0.0.0 0.255.255.255 a
R4(config-router)#network 3.0.0.0 0.255.255.255 area 0
R4(config-router)#exit
R4(config)#router rip
R4(config-router)#version 2
R4(config-router)#network 45.0.0.0
R4(config-router)#network 14.0.0.0
R4(config-router)#no auto-summary
R4(config)#router eigrp 140
R4(config-router)#network 4.0.0.0
R4(config-router)#network 40.0.0.0
R5(config)#router rip
R5(config-router)#ver 2
R5(config-router)#network 45.0.0.0
R5(config-router)#no auto-summary
R5(config-router)#exit
R5(config)#router ospf 11
R5(config-router)#network 24.0.0.0 0.255.255.255 a
R5(config-router)#network 24.0.0.0 0.255.255.255 area 0
R5(config-router)#network 50.0.0.0 0.255.255.255 area 0
R5(config)#router eigrp 53
R5(config-router)#network 35.0.0.0
R5(config-router)#network 150.0.0.0
R5(config-router)#version 2
R5(config-router)#network 15.0.0.0
R1#show ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "eigrp 210"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Default networks flagged in outgoing updates
  Default networks accepted from incoming updates
  EIGRP-IPv4 Protocol for AS(210)
    Metric weight K1=1, K2=0, K3=1, K4=0, K5=0
    NSF-aware route hold timer is 240
    Router-ID: 11.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Distance: internal 90 external 170
      Maximum path: 4
      Maximum hopcount 100
      Maximum metric variance 1
  Automatic Summarization: disabled
  Maximum path: 4
  Routing for Networks:
    1.0.0.0
    10.0.0.0
  Routing Information Sources:
    Gateway         Distance      Last Update
    1.1.1.2               90      00:38:42
Routing Protocol is "rip"
  Sending updates every 30 seconds, next due in 23 seconds
  Invalid after 180 seconds, hold down 180, flushed after 240
  Redistributing: rip
  Default version control: send version 2, receive version 2
    Interface             Send  Recv  Triggered RIP  Key-chain
    Serial3/6             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Automatic network summarization is not in effect
  Maximum path: 4
    11.0.0.0
    15.0.0.0
  Distance: (default is 120)
Routing Protocol is "eigrp 140"
  EIGRP-IPv4 Protocol for AS(140)
    Router-ID: 11.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    4.0.0.0
    4.1.1.1               90      00:20:14
R2#show ip protocols
    Router-ID: 12.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    1.0.0.0
    20.0.0.0
    1.1.1.1               90      00:39:50
  Sending updates every 30 seconds, next due in 7 seconds
  Redistributing: rip
    Serial3/1             2     2
  Automatic network summarization is in effect
  Maximum path: 4
    2.0.0.0
    11.0.0.0
    2.1.1.2              120      00:00:27
Routing Protocol is "ospf 11"
  Router ID 12.0.3.1
  Number of areas in this router is 1. 1 normal 0 stub 0 nssa
  Maximum path: 4
  Distance: (default is 110)
R3#show ip protocols
  Sending updates every 30 seconds, next due in 11 seconds
  Redistributing: rip
    Serial3/1             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    2.0.0.0
    13.0.0.0
Routing Protocol is "eigrp 53"
  EIGRP-IPv4 Protocol for AS(53)
    Router-ID: 13.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    30.0.0.0
    35.0.0.0
    35.1.1.2              90      00:29:09
Routing Protocol is "ospf 10"
  Router ID 13.0.3.1
  Maximum path: 4
R4#show ip protocols
  Router ID 14.0.3.1
  Maximum path: 4
  Sending updates every 30 seconds, next due in 28 seconds
  Redistributing: rip
    Serial3/7             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    14.0.0.0
    45.0.0.0
    45.1.1.2             120      00:00:11
    Router-ID: 14.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    4.0.0.0
    40.0.0.0
R5#show ip protocols
  Router ID 150.0.3.1
  Maximum path: 4
    Router-ID: 150.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    35.0.0.0
    150.0.0.0
    35.1.1.1              90      00:30:12
  Sending updates every 30 seconds, next due in 20 seconds
  Redistributing: rip
    Serial3/6             2     2
    Serial3/7             2     2
  Maximum path: 4
    15.0.0.0
    45.0.0.0
    45.1.1.1             120      00:00:01
R1(config-router)#redistribute rip metric 1000 20000 255 1 1500
R1(config-router)#redistribute eigrp 140 metric 1000 20000 255 1 1500
R1(config-router)#redistribute eigrp 210 metric 8
R1(config-router)#redistribute eigrp 140 metric 8
R1(config-router)#redistribute eigrp 210 metric  1000 20000 255 1 1500
R2(config-router)#redistribute ospf 11 metric 1000 20000 255 1 1500
R2(config-router)#redistribute rip  metric 1000 20000 255 1 1500
R2(config-router)#redistribute ospf 11 metric 8
R2(config-router)#redistribute eigrp 210  metric 8
R2(config-router)#redistribute eigrp 210 subnets metric-type 1
R2(config-router)#redistribute rip  subnets metric-type 1
R3(config-router)#redistribute eigrp 53 metric 8
R3(config-router)#redistribute ospf 10  metric 8
R3(config-router)#redistribute rip metric 1000 20000 255 1 1500
R3(config-router)#redistribute ospf 10  metric 1000 20000 255 1 1500
R3(config-router)#redistribute rip subnets metric-type 1
R3(config-router)#redistribute eigrp 53  subnets metric-type 1
R4(config-router)#redistribute rip subnets metric-type 1
R4(config-router)#redistribute eigrp 140  subnets metric-type 1
R4(config-router)#redistribute eigrp 140 metric 8
R4(config-router)#redistribute ospf 10  metric 8
R4(config-router)#redistribute rip metric 1000 20000 255 1 1500
R4(config-router)#redistribute ospf 10  metric 1000 20000 255 1 1500
R5(config-router)#redistribute eigrp 53 subnets metric-type 1
R5(config-router)#redistribute rip  subnets metric-type 1
R5(config-router)#redistribute eigrp 53 metric 8
R5(config-router)#redistribute ospf 11 metric 8
R5(config-router)#redistribute ospf 11 metric 1000 20000 255 1 1500
R5(config-router)#redistribute rip  metric 1000 20000 255 1 1500
R1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        1.0.0.0/8 is directly connected, Serial3/0
L        1.1.1.1/32 is directly connected, Serial3/0
D EX  2.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX  3.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
      4.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        4.0.0.0/8 is directly connected, Serial3/3
L        4.1.1.2/32 is directly connected, Serial3/3
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/8 is directly connected, FastEthernet0/0
L        10.1.1.1/32 is directly connected, FastEthernet0/0
      11.0.0.0/8 is variably subnetted, 9 subnets, 3 masks
D EX     11.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:50, Serial3/3
C        11.0.0.0/24 is directly connected, Loopback0
L        11.0.0.1/32 is directly connected, Loopback0
C        11.0.1.0/24 is directly connected, Loopback1
L        11.0.1.1/32 is directly connected, Loopback1
C        11.0.2.0/24 is directly connected, Loopback2
L        11.0.2.1/32 is directly connected, Loopback2
C        11.0.3.0/24 is directly connected, Loopback3
L        11.0.3.1/32 is directly connected, Loopback3
      12.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
D EX     12.0.0.0/8 [170/8192000] via 4.1.1.1, 00:09:50, Serial3/3
D EX     12.0.0.0/24 [170/8192000] via 1.1.1.2, 00:09:52, Serial3/0
D EX     12.0.1.0/24 [170/8192000] via 1.1.1.2, 00:09:52, Serial3/0
D EX     12.0.2.0/24 [170/8192000] via 1.1.1.2, 00:09:52, Serial3/0
D EX     12.0.3.0/24 [170/8192000] via 1.1.1.2, 00:09:52, Serial3/0
      13.0.0.0/24 is subnetted, 4 subnets
D EX     13.0.0.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     13.0.1.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     13.0.2.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     13.0.3.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
      14.0.0.0/24 is subnetted, 4 subnets
D EX     14.0.0.0 [170/8192000] via 4.1.1.1, 00:18:59, Serial3/3
D EX     14.0.1.0 [170/8192000] via 4.1.1.1, 00:18:59, Serial3/3
D EX     14.0.2.0 [170/8192000] via 4.1.1.1, 00:18:59, Serial3/3
D EX     14.0.3.0 [170/8192000] via 4.1.1.1, 00:18:59, Serial3/3
      15.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        15.0.0.0/8 is directly connected, Serial3/6
L        15.1.1.1/32 is directly connected, Serial3/6
D     20.0.0.0/8 [90/2172416] via 1.1.1.2, 01:29:11, Serial3/0
D EX  24.0.0.0/8 [170/8192000] via 4.1.1.1, 00:15:10, Serial3/3
D EX  30.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX  35.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D     40.0.0.0/8 [90/2172416] via 4.1.1.1, 01:10:38, Serial3/3
D EX  45.0.0.0/8 [170/8192000] via 4.1.1.1, 00:18:59, Serial3/3
D EX  50.0.0.0/8 [170/8192000] via 4.1.1.1, 00:15:10, Serial3/3
      150.0.0.0/24 is subnetted, 4 subnets
D EX     150.0.0.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     150.0.1.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     150.0.2.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
D EX     150.0.3.0 [170/8192000] via 4.1.1.1, 00:18:49, Serial3/3
R2#show ip route
L        1.1.1.2/32 is directly connected, Serial3/0
      2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        2.0.0.0/8 is directly connected, Serial3/1
L        2.1.1.1/32 is directly connected, Serial3/1
R     3.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R     4.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
D     10.0.0.0/8 [90/2172416] via 1.1.1.1, 00:10:26, Serial3/0
      11.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
D EX     11.0.0.0/8 [170/8192000] via 1.1.1.1, 00:10:26, Serial3/0
R        11.0.0.0/24 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        11.0.1.0/24 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        11.0.2.0/24 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        11.0.3.0/24 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
      12.0.0.0/8 is variably subnetted, 9 subnets, 3 masks
D EX     12.0.0.0/8 [170/8192000] via 1.1.1.1, 00:10:26, Serial3/0
C        12.0.0.0/24 is directly connected, Loopback0
L        12.0.0.1/32 is directly connected, Loopback0
C        12.0.1.0/24 is directly connected, Loopback1
L        12.0.1.1/32 is directly connected, Loopback1
C        12.0.2.0/24 is directly connected, Loopback2
L        12.0.2.1/32 is directly connected, Loopback2
C        12.0.3.0/24 is directly connected, Loopback3
L        12.0.3.1/32 is directly connected, Loopback3
R        13.0.0.0 [120/1] via 2.1.1.2, 00:00:08, Serial3/1
R        13.0.1.0 [120/1] via 2.1.1.2, 00:00:08, Serial3/1
R        13.0.2.0 [120/1] via 2.1.1.2, 00:00:08, Serial3/1
R        13.0.3.0 [120/1] via 2.1.1.2, 00:00:08, Serial3/1
R        14.0.0.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        14.0.1.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        14.0.2.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        14.0.3.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
D EX  15.0.0.0/8 [170/8192000] via 1.1.1.1, 00:10:26, Serial3/0
      20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        20.0.0.0/8 is directly connected, FastEthernet0/0
L        20.1.1.1/32 is directly connected, FastEthernet0/0
      24.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        24.0.0.0/8 is directly connected, Serial3/4
L        24.1.1.1/32 is directly connected, Serial3/4
R     30.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R     35.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R     40.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R     45.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R     50.0.0.0/8 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        150.0.0.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        150.0.1.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        150.0.2.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R        150.0.3.0 [120/8] via 2.1.1.2, 00:00:08, Serial3/1
R3#show ip route
R     1.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
L        2.1.1.2/32 is directly connected, Serial3/1
      3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        3.0.0.0/8 is directly connected, Serial3/2
L        3.1.1.1/32 is directly connected, Serial3/2
O E1  4.0.0.0/8 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
R     10.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
R        11.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
O E1     11.0.0.0/24 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
O E1     11.0.1.0/24 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
O E1     11.0.2.0/24 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
O E1     11.0.3.0/24 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
R        12.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
O E1     12.0.0.0/24 [110/84] via 3.1.1.2, 00:11:03, Serial3/2
O E1     12.0.1.0/24 [110/84] via 3.1.1.2, 00:11:03, Serial3/2
O E1     12.0.2.0/24 [110/84] via 3.1.1.2, 00:11:03, Serial3/2
O E1     12.0.3.0/24 [110/84] via 3.1.1.2, 00:11:03, Serial3/2
      13.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C        13.0.0.0/24 is directly connected, Loopback0
L        13.0.0.1/32 is directly connected, Loopback0
C        13.0.1.0/24 is directly connected, Loopback1
L        13.0.1.1/32 is directly connected, Loopback1
C        13.0.2.0/24 is directly connected, Loopback2
L        13.0.2.1/32 is directly connected, Loopback2
C        13.0.3.0/24 is directly connected, Loopback3
L        13.0.3.1/32 is directly connected, Loopback3
O E1     14.0.0.0 [110/84] via 3.1.1.2, 00:22:05, Serial3/2
O E1     14.0.1.0 [110/84] via 3.1.1.2, 00:22:05, Serial3/2
O E1     14.0.2.0 [110/84] via 3.1.1.2, 00:22:05, Serial3/2
O E1     14.0.3.0 [110/84] via 3.1.1.2, 00:22:05, Serial3/2
R     15.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
R     20.0.0.0/8 [120/8] via 2.1.1.1, 00:00:10, Serial3/1
O E1  24.0.0.0/8 [110/84] via 3.1.1.2, 00:16:21, Serial3/2
      30.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        30.0.0.0/8 is directly connected, FastEthernet0/0
L        30.1.1.1/32 is directly connected, FastEthernet0/0
      35.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        35.0.0.0/8 is directly connected, Serial3/5
L        35.1.1.1/32 is directly connected, Serial3/5
O E1  40.0.0.0/8 [110/84] via 3.1.1.2, 00:21:54, Serial3/2
O E1  45.0.0.0/8 [110/84] via 3.1.1.2, 00:22:05, Serial3/2
O E1  50.0.0.0/8 [110/84] via 3.1.1.2, 00:16:21, Serial3/2
D        150.0.0.0 [90/2297856] via 35.1.1.2, 01:19:24, Serial3/5
D        150.0.1.0 [90/2297856] via 35.1.1.2, 01:19:24, Serial3/5
D        150.0.2.0 [90/2297856] via 35.1.1.2, 01:19:24, Serial3/5
D        150.0.3.0 [90/2297856] via 35.1.1.2, 01:19:24, Serial3/5
R4#show ip route
O E1  1.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1  2.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
L        3.1.1.2/32 is directly connected, Serial3/2
L        4.1.1.1/32 is directly connected, Serial3/3
O E1  10.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1     11.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
D EX     11.0.0.0/24 [170/8192000] via 4.1.1.2, 00:40:04, Serial3/3
D EX     11.0.1.0/24 [170/8192000] via 4.1.1.2, 00:40:04, Serial3/3
D EX     11.0.2.0/24 [170/8192000] via 4.1.1.2, 00:40:04, Serial3/3
D EX     11.0.3.0/24 [170/8192000] via 4.1.1.2, 00:40:04, Serial3/3
O E1     12.0.0.0/8 [110/84] via 3.1.1.1, 00:11:29, Serial3/2
D EX     12.0.0.0/24 [170/8192000] via 4.1.1.2, 00:11:30, Serial3/3
D EX     12.0.1.0/24 [170/8192000] via 4.1.1.2, 00:11:30, Serial3/3
D EX     12.0.2.0/24 [170/8192000] via 4.1.1.2, 00:11:30, Serial3/3
D EX     12.0.3.0/24 [170/8192000] via 4.1.1.2, 00:11:30, Serial3/3
O E1     13.0.0.0 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1     13.0.1.0 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1     13.0.2.0 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1     13.0.3.0 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
      14.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C        14.0.0.0/24 is directly connected, Loopback0
L        14.0.0.1/32 is directly connected, Loopback0
C        14.0.1.0/24 is directly connected, Loopback1
L        14.0.1.1/32 is directly connected, Loopback1
C        14.0.2.0/24 is directly connected, Loopback2
L        14.0.2.1/32 is directly connected, Loopback2
C        14.0.3.0/24 is directly connected, Loopback3
L        14.0.3.1/32 is directly connected, Loopback3
O E1  15.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
O E1  20.0.0.0/8 [110/84] via 3.1.1.1, 00:25:48, Serial3/2
R     24.0.0.0/8 [120/8] via 45.1.1.2, 00:00:16, Serial3/7
O E1  30.0.0.0/8 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
O E1  35.0.0.0/8 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
      40.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        40.0.0.0/8 is directly connected, FastEthernet0/0
L        40.1.1.1/32 is directly connected, FastEthernet0/0
      45.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        45.0.0.0/8 is directly connected, Serial3/7
L        45.1.1.1/32 is directly connected, Serial3/7
R     50.0.0.0/8 [120/8] via 45.1.1.2, 00:00:16, Serial3/7
O E1     150.0.0.0 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
O E1     150.0.1.0 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
O E1     150.0.2.0 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
O E1     150.0.3.0 [110/84] via 3.1.1.1, 00:25:38, Serial3/2
R5#show ip route
R     1.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R     2.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R     3.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R     4.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R     10.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        11.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        11.0.0.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        11.0.1.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        11.0.2.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        11.0.3.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        12.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        12.0.0.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        12.0.1.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        12.0.2.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        12.0.3.0/24 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        13.0.0.0 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        13.0.1.0 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        13.0.2.0 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        13.0.3.0 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
R        14.0.0.0 [120/1] via 45.1.1.1, 00:00:11, Serial3/7
R        14.0.1.0 [120/1] via 45.1.1.1, 00:00:11, Serial3/7
R        14.0.2.0 [120/1] via 45.1.1.1, 00:00:11, Serial3/7
R        14.0.3.0 [120/1] via 45.1.1.1, 00:00:11, Serial3/7
R     20.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
L        24.1.1.2/32 is directly connected, Serial3/4
D     30.0.0.0/8 [90/2172416] via 35.1.1.1, 01:20:22, Serial3/5
L        35.1.1.2/32 is directly connected, Serial3/5
R     40.0.0.0/8 [120/8] via 45.1.1.1, 00:00:11, Serial3/7
L        45.1.1.2/32 is directly connected, Serial3/7
      50.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        50.0.0.0/8 is directly connected, FastEthernet0/0
L        50.1.1.1/32 is directly connected, FastEthernet0/0
      150.0.0.0/16 is variably subnetted, 8 subnets, 2 masks
C        150.0.0.0/24 is directly connected, Loopback0
L        150.0.0.1/32 is directly connected, Loopback0
C        150.0.1.0/24 is directly connected, Loopback1
L        150.0.1.1/32 is directly connected, Loopback1
C        150.0.2.0/24 is directly connected, Loopback2
L        150.0.2.1/32 is directly connected, Loopback2
C        150.0.3.0/24 is directly connected, Loopback3
L        150.0.3.1/32 is directly connected, Loopback3
  Redistributing: rip, eigrp 140
    Router-ID: 11.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    1.0.0.0
    10.0.0.0
    1.1.1.2               90      00:12:16
  Sending updates every 30 seconds, next due in 21 seconds
  Redistributing: eigrp 210, eigrp 140
    Serial3/6             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    11.0.0.0
    15.0.0.0
  Redistributing: eigrp 210, rip
    Router-ID: 11.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    4.0.0.0
    4.1.1.1               90      00:12:22
  Redistributing: rip, ospf 11
    Router-ID: 12.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    1.0.0.0
    20.0.0.0
    1.1.1.1               90      00:14:01
  Sending updates every 30 seconds, next due in 26 seconds
  Redistributing: eigrp 210, rip, ospf 11 (internal, external 1 & 2, nssa-external 1 & 2)
    Serial3/1             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    2.0.0.0
    12.0.0.0
    2.1.1.2              120      00:00:07
  Router ID 12.0.3.1
  It is an autonomous system boundary router
 Redistributing External Routes from,
    eigrp 210, includes subnets in redistribution
    rip, includes subnets in redistribution
  Maximum path: 4
  Sending updates every 30 seconds, next due in 14 seconds
  Redistributing: rip, eigrp 53, ospf 10 (internal, external 1 & 2, nssa-external 1 & 2)
    Serial3/1             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    2.0.0.0
    13.0.0.0
    2.1.1.1              120      00:00:19
  Redistributing: rip, ospf 10
    Router-ID: 13.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    30.0.0.0
    35.0.0.0
    35.1.1.2              90      00:15:41
  Router ID 13.0.3.1
    eigrp 53, includes subnets in redistribution
  Maximum path: 4
    14.0.3.1             110      00:15:48
  Router ID 14.0.3.1
    eigrp 140, includes subnets in redistribution
  Maximum path: 4
    13.0.3.1             110      00:17:00
  Sending updates every 30 seconds, next due in 16 seconds
  Redistributing: ospf 10 (internal, external 1 & 2, nssa-external 1 & 2)
    Serial3/7             2     2
    Loopback0             2     2
    Loopback1             2     2
    Loopback2             2     2
    Loopback3             2     2
  Maximum path: 4
    14.0.0.0
    45.0.0.0
    45.1.1.2             120      00:00:12
  Redistributing: ospf 10, rip
    Router-ID: 14.0.3.1
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    4.0.0.0
    40.0.0.0
    4.1.1.2               90      00:17:04
  Router ID 150.0.3.1
  Maximum path: 4
  Redistributing: ospf 11, rip
    Topology : 0 (base)
      Active Timer: 3 min
      Maximum path: 4
  Maximum path: 4
    35.0.0.0
    150.0.0.0
    35.1.1.1              90      00:18:32
  Sending updates every 30 seconds, next due in 25 seconds
  Redistributing: ospf 11 (internal, external 1 & 2, nssa-external 1 & 2)
  Redistributing: eigrp 53, rip
    Serial3/6             2     2
    Serial3/7             2     2
  Maximum path: 4
    15.0.0.0
    45.0.0.0
    45.1.1.1             120      00:00:22
1 Comment
Deepak Kumar
May I know why did you select below metric:
Is this route not trustworthy? and Is it recommended?
Deepak Kumar
