Cisco NDFC Installation issue
Han_Sen
Hi, all, i'm facing an issue while installing NDFC on a ESXI server. please check the following image.
It's still not working even i execute the command "acs upgrade recover AppActivate".
Anyone can help me on this? Thanks.
7 Replies 7
Hello @Han_Sen ,
Have you tried the recommended actions described in the Failed to activate error message?
Regards, LG
*** Please Rate All Helpful Responses ***
Hi, yes, i've tried it but not working...
kagunase
any update on this issue? am also facing same and i tried the "acs upgrade recover AppActivate" but no luck..
Can you check you if you are hitting CSCwm35992Nexus Dashboard upgrade to 3.2.1e will fail if the name of the imported CA has a space in the name.
Regards, LG
kagunase
thanks for the reply. it does not have any CA certificate as of now.
kagunase
I'm thinking of getting TAC involved.
Regards, LG
