02-06-2025 09:40 AM - edited 02-16-2025 07:40 AM
I'm running into a problem with NDFC where the Border Gateways don't exchange EBGP routes in a Multi-Site setup. It's the same problem described here, but there's no answer.
The debug message on the Border Gateway Spine is:
2025 Feb 6 17:29:32.099557 bgp: 65002 [30656] (default) UPD: [L2VPN EVPN] 10.112.0.1 10.2.0.2:35067:[2]:[0]:[0]:[48]:[aaaa.bbbb.0444]:[0]:[0.0.0.0]/216 path-id 1 not sent to peer due to: EVPN Border Gateway: no crossing via remote RD
Anyone have an idea what this error means?
The BGP config generated by NDFC is:
router bgp 65002
router-id 10.2.0.3
log-neighbor-changes
address-family ipv4 unicast
redistribute direct route-map rmap-redist-direct
maximum-paths 64
maximum-paths ibgp 64
address-family ipv6 unicast
maximum-paths 64
address-family ipv4 mvpn
address-family l2vpn evpn
neighbor 10.2.0.1
remote-as 65002
update-source loopback0
send-community
send-community extended
route-reflector-client
send-community
neighbor 10.2.0.2
remote-as 65002
send-community
send-community
neighbor 10.10.1.6
remote-as 65111
update-source Ethernet1/7
next-hop-self
neighbor 10.112.0.1
remote-as 65001
ebgp-multihop 5
peer-type fabric-external
send-community
rewrite-evpn-rt-asn
evpn
Solved! Go to Solution.
02-23-2025 06:14 AM
In case anyone is reading this in the future... I finally found the issue : )
This log means that the VNIs aren't advertised between sites because those Networks are not attached to the Border Gateway.
Once you "attach" the Network to the Border Gateway, like you do a Leaf, it will start advertising that segment.
02-09-2025 12:16 PM
@Robert Burns have you seen this error before?
02-14-2025 07:13 AM - edited 02-14-2025 07:14 AM
@Lukas Krattiger I'm grasping at straws
Any idea what this error means?
02-23-2025 06:14 AM
