NDFC Deploy Issues
kmelchior
I am new to NDFC. I have my fabric built and switches discovered. I am trying to do the configuration but no matter what I am configuring I cannot 'deploy' the config. It is just not an option, more or less 'greyed out'. I can 'recalculate' after making any changes but on the next screen 'deploy all' is greyed out. Any suggestions would be appreciated.
Thanks!
dodgerfan78
Did you fix this? Mine are stuck in Migration mode and nothing will change them.
CSCO12101118
If a VPC pair is not selected after seeding the switch then, switches will be stuck in Migration mode
