vpc advertise-pip versus vpc advertise-pip border only
WILLIAM STEGMAN
Level 4
Level 4
Why would someone choose to use vpc advertise-pip border only rather than vpc advertise-pip?  I'm looking for a circumstance/example that would make you lean one direction or the other.  If you have vpc facing hosts within the fabric, isn't it ideal to have the advertise-pip setting?  When would you choose to only enable it on the border?
thanks
Deepak Bansal
You need to enable vpc advertise-pip for all the vpc peers, irrespective if its vPC boarder lead or compute leaf's.
