Can we make layer 3 port channel as a vpc member
binoyb
All,
I want to know if we can set a layer 3 port channel as a VPC member , I cant find any configuration based on this Eg:  Nexus 9000 -Sw1 and Nexus 9000 Sw2 ( Set with vPC domain /keep alive/Peer-link) -Port channel 7  ip add 7.7.7.1/30)  <--->Connects to a Router/Fw  7.7.7.2/30 . So Question is Can the Port-channel 7 (L3 Port channel)  at Nexus side be added as a vpc member Eg  int po7  ip add 7.7.7.2/30  vpc 7. I was not able to do that in emulator so was thinking it is not possible in L3 Port channel and only possible in L2 Port channel ,  but wanted to verify .
2 Accepted Solutions
Sergiu.Daniluk
Hi @binoyb
Layer 3 port-channels cannot be configured as vPC.
Stay safe,
Sergiu
No you cant but
You can config svl for vlan pass through l2 vpc which give same.
Sergiu.Daniluk
Hi @binoyb
Stay safe,
Sergiu
No you cant but
