Can't create FLEX LINKS on CISCO C9372PX
djamil aklouche
Hello guys,
I'm trying to configure FLEX Links on a C9372PX CISCO SWITCH, but when I try to add run the: feature flexlink command, nothing shows up.
Are the cisco C9372PX able to use flex links for L1 backup and active ports or not?
If not, is there any other mechanism to have such behavior other than using flex links ?
Thanks in advance
Sergiu.Daniluk
Hi @djamil aklouche
Based on the config guide, it's not supported on any gen1 Nexus 9000, including your 9397PX:
Stay safe,
Sergiu
Hi !
Oh well, that's unfortunate. Is there any otherr equivalent solution in order to have standby/Active links on those kind of switchs ?
