Nexus 7700 LACP+QinQ
Peyman Zadmehr
According my searches, N3K has problem for having QinQ feature on a L2 Port-Channel(LACP). I want to ask Does N7710 Have this limitation?
Thank you
Yes. It refers to the GRE tunnel. Same paragraph is written under the "IP Tunnels" section. So I guess it was a copy paste in the documentation without correction.
Cheers,
Sergiu
Sergiu.Daniluk
No problem. N7K supports Q-in-Q on port-channels and vPC:
Q-in-Q is supported on port channels and virtual port channels (vPCs). To configure a port channel as an asymmetrical link, all ports in the port channel must have the same tunneling configuration.
Reference: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/interfaces/config/cisco_nexus7000_interfaces_config_guide_8x/config-q-in-q-vlan-tunnels.html#reference_DB359015117B420FB7549955747879C7
Stay safe,
Sergiu
In the mentioned link under "Licensing Requirements for Q-in-Q VLAN Tunnels" section, It was mentioned:
IP tunnels require an Enterprise Services license.
I want to ask what is this "IP Tunnel"? GRE? does this mean the GRE tunnel sourced from the switch?
Thank you
Cheers,
Sergiu
