08-29-2021 09:24 AM
I'm having some issues with a simple vxlan setup using static ingress replication.
The Anycast vPC pair's VTEP doesn't seem to be responsive at all. I do not see any vxlan encapsulated frames being generated from either of these switches. No encapsulated L2 traffic is being sent across the vxlan underlay if its being generated on the vPC pair side. I am able to see encapsulated L2 traffic being sent from the single 9K (10.51.8.50) towards to the pair. I see the packet coming in (ARP) but it doesn't appear to be decapsulated and forwarded to VLAN 500.
I've dropped the MTU on the originating hosts to 1400 to get across my WAN link as its limited to 1500.
I have verified L3 connectivity:
ping 10.51.8.50 source-interface lo50 ping 10.243.13.50 source-interface lo50
I have verified the nve peer:
Interface Peer-IP State LearnType Uptime Router-Mac --------- -------------------------------------- ----- --------- -------- ----------------- nve1 10.51.8.50 Up DP 5d02h n/a
The vPC link appears good:
vPC domain id : 100 Peer status : peer adjacency formed ok vPC keep-alive status : peer is alive Configuration consistency status : success Per-vlan consistency status : success Type-2 consistency status : success vPC role : primary Number of vPCs configured : 50 Peer Gateway : Disabled Dual-active excluded VLANs : 2 Graceful Consistency Check : Enabled Auto-recovery status : Enabled, timer is off.(timeout = 240s) Delay-restore status : Timer is off.(timeout = 30s) Delay-restore SVI status : Timer is off.(timeout = 10s) Operational Layer3 Peer-router : Disabled Virtual-peerlink mode : Disabled
Config relating to vxlan:
1-SW1:
tware BIOS: version 05.31 NXOS: version 9.3(1) BIOS compile time: 05/17/2018 NXOS image file is: bootflash:///nxos.9.3.1.bin NXOS compile time: 7/18/2019 15:00:00 [07/19/2019 00:04:48] Hardware cisco Nexus9000 C93180YC-FX Chassis Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 65808228 kB of memory. Processor Board ID FDO22282THV
vlan 500 name VxLAN vn-segment 5000 interface Vlan500 description vxlan-segment 5000 - 10.100.1.0/23 no shutdown mtu 1500 ip address 10.100.1.250/23 interface nve1 no shutdown source-interface loopback50 member vni 5000 ingress-replication protocol static peer-ip 10.51.8.50 interface loopback50 description VxLAN - VN5000 ip address 10.241.13.51/32 ip address 10.241.13.50/32 secondary
1-SW2:
vlan 500 name VxLAN vn-segment 5000 interface Vlan500 description vxlan-segment 5000 - 10.100.1.0/23 no shutdown mtu 1500 ip address 10.100.1.251/23 interface nve1 no shutdown source-interface loopback50 member vni 5000 ingress-replication protocol static peer-ip 10.51.8.50 interface loopback50 description VxLAN - VN5000 ip address 10.241.13.52/32 ip address 10.241.13.50/32 secondary
2-SW1
IOS: version 05.38 NXOS: version 9.3(1) BIOS compile time: 06/12/2019 NXOS image file is: bootflash:///nxos.9.3.1.bin NXOS compile time: 7/18/2019 15:00:00 [07/19/2019 00:04:48] Hardware cisco Nexus9000 C93240YC-FX2 Chassis Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 16337464 kB of memory. Processor Board ID FDO22390YLA
vlan 500 name VxLAN vn-segment 5000 interface Vlan500 description vxlan-segment 5000 - 10.100.1.0/23 no shutdown mtu 1500 ip address 10.100.1.252/23 interface nve1 no shutdown source-interface loopback50 member vni 5000 ingress-replication protocol static peer-ip 10.241.13.50 interface loopback50 description VxLAN - VN5000 ip address 10.51.8.50/32
Any ideas why the vPC pairs VTEP seems to be dead?
11-25-2021 12:39 PM - edited 11-25-2021 12:41 PM
As far as I see in the provided outputs, you have "peer-gateway" disabled. This must be enabled for vpc peers with vxlan. Not sure if this is causing the problem here, but let's first get the configuration up to date.
Later edit: "peer-gateway (...) facilitates NVE RMAC/VMAC programming on both peers"
Stay safe,
Sergiu
