Access onboarding info from template
franjorge
I was wondering if there is a way to access the data introduced at on-boarding time in order to populate a template.
Let's say we have provisioned these devices:
admin@ncs# show devices list
NAME     ADDRESS          DESCRIPTION   NED ID                 ADMIN STATE
Test1    172.70.41.252    -             juniper-junos-nc-4.5   unlocked
Test2    172.70.41.253    -             juniper-junos-nc-4.5   unlocked
We also have a service, with a parameter that is the peer-router. Applying the service to Test1 device would be something like:
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# service1 Test1 peer-router Test2
Can we somehow in the service template reference the ADDRESS field of device Test2 in order to set, for example, the allowed LDP session peers of Test1?
Thanks.
franjorge
Never mind, I found the answer for myself:
{/../ncs:devices/ncs:device[name=/peer-router]/ncs:address}
