09-09-2022 06:48 AM - edited 09-09-2022 06:49 AM
I have a problem with kicker invocation, ncs cant find the action, It says that doesn't exist. Even if I change the action-name with another I have the same problem. If I call the action directly from the cli I have no problem, all my actions works well, but the kicker cant find them for some reason
<INFO> 9-Sep-2022::13:16:28.317 37693c46734f ncs[1]: ncs progress usid=1835 tid=59488 datastore=running context=cli check data kickers
<ERR> 9-Sep-2022::13:16:28.318 37693c46734f ncs[1]: ncs Action, addmdu, does not exist
kickers data-kicker mdurequest
monitor /services/pon/actions/mdu-request
kick-node mgmt-ip-address
action-name addmdu
augment "/ncs:services/pon:pon/pon:actions" {
list mdu-request {
key "olt rack shelf slot port onuid";
uses input-onu;
leaf mgmt-ip-address {
mandatory true;
type inet:ip-address;
tailf:action addmdu {
tailf:actionpoint addmdu;
input {
uses kicker:action-input-params;
output {
leaf message {
type string;
actionpoints:
id=addmdu daemonId=1271 daemonName=ncs-dp-18324-pon-actions:config-mdu callbacks=action,init
admin@ncs(config)# services pon actions mdu-request CEYD-01Z 1 1 3 1 70 mgmt-ip-address 192.168.7.3
admin@ncs(config-mdu-request-CEYD-01Z/1/1/3/1/70)# commit | debug kicker 2022-09-09T13:46:20.064 kicker: mdurequest at /ncs:services/pon:pon/pon:actions/config-mdu:mdu-request[config-mdu:olt='CEYD-01Z'][config-mdu:rack='1'][config-mdu:shelf='1'][config-mdu:slot='3'][config-mdu:port='1'][config-mdu:onuid='70'] changed; invoking addmdu
Commit complete.
Solved! Go to Solution.
09-10-2022 01:24 AM
The action does not exist as you are invoking it from wrong location.
If you want it triggered for any change under mdu-request you could try something like this:
kick-node .
action-name addmdu
Or if you want it triggered only when mgmt-ip-address is change you could try something like this:
monitor /services/pon/actions/mdu-request/mgmt-ip-address
kick-node ../
action-name addmdu
br.
Kristoffer Larsen
09-09-2022 10:34 AM
It looks like the action is not registered with the Python/Java process. In Python code for the action you should have this:
class ActionClass(Action):
@Action.action
def cb_action(self, uinfo, name, kp, _input, output, trans):
self.log.debug(f"Entered cb_action {name}")
class Main(ncs.application.Application):
def setup(self
# The application class sets up logging for us. It is accessible
# through 'self.log' and is a ncs.log.Log instance.
self.log.info('Main RUNNING')
# When using actions, this is how we register them:
self.register_action('addmdu', ActionClass)
When you reload the package you should see in the log for your package that your action is registered.
<INFO> 08-Sep-2022::17:18:06.188 <name-of-the-package> ComponentThread:addmdu: - Main RUNNING
Yan
09-10-2022 01:24 AM
kick-node .
action-name addmdu
kick-node ../
action-name addmdu
br.
Kristoffer Larsen
09-19-2022 06:02 AM
That works, thank you!
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
