correct xmlns for BGP service package
DeanMoore
Morning,
I'm struggling with part of NSO service package creation.
Although I was able to push config to a specific device via restconf I want to move the BGP config to a service template.
When I reload the package I get an error as per below but not sure what I should be putting in its place.
This is my template xml
<config>
                <ip xmlns="urn:ios">
                        <route>
                                <ip-route-interface-list>
                                        <prefix>{/neighbour_static}</prefix>
                                        <mask>{/neighbour_mask}</mask>
                                        <interface>{/neighbour_interface}</interface>
                                </ip-route-interface-list>
                        </route>
                </ip>
                <router xmlns="urn:cisco-ios-cli-3.8">
                        <bgp>
                                <as-no>{/local_as}</as-no>
                                <bgp>
                                        <log-neighbor-changes/>
                                </bgp>
                                <neighbor>
                                        <id>{/remote_ip}</id>
                                        <remote-as>{/remote_as}</remote-as>
                                </neighbor>
                                <auto-summary>false</auto-summary>
                                <timers>
                                        <bgp>
                                                <keepalive>10</keepalive>
                                                <holdtime>30</holdtime>
                                        </bgp>
                                </timers>
                        </bgp>
                </router>
      </config>
This is the yang model, I know its not perfect but it would be ok.
    container static_route {
        leaf neighbour_static {
                type inet:ipv4-address;
        leaf neighbour_mask {
        leaf neighbour_interface {
                type string;
    container bgp {
        leaf local_as {
                type uint32;
        container neigbour {
                leaf neighbour_ip {
                leaf remote_as {
                        type uint32;
and finally the error I get when issuing package reload
reload-result {
    package bgp-service
    result false
    info bgp-service-template.xml:21 Unknown namespace: 'urn:cisco-ios-cli-3.8'
Hello -
so here is what I think is happening:
0. Assumption you have NSO 5.x
1. you have the two default NEDs loaded for cisco-ios (that is 3.0 and 3.8 - you can check with `show packages package oper-status`)
2. the error comes from the `bgp` keyword inside timers
in cisco-ios-cli-3.8 - you have an intermediate "bgp" layer in timers:
in cisco-ios-cli-3.0 - the "bgp" layer in timers does not exist:
The error comes from the fact that your templates is trying to configure this leaf for an "ambiguous" namespace.
Essentially this is the same error as in:
https://community.cisco.com/t5/nso-developer-hub-discussions/error-element-only-exist-for-a-ned-id/m-p/4034137
And the solutions are:
1. remove the cisco-ios-cli-3.0 if you don't need it - packages reload (first answer in the thread)
2. Use the <?if ned-id ...?> syntax in your template as described in the second answer of the thread and in nso_cdm_migration guide in the section "Service Handling of ambiguous device models" - "Template Service" - and packages reload
Guillaume
DeanMoore
After adding xmlns="urn:ios" I get this output which is where I got the cisco-ios-cli-3.8 from
reload-result {
package bgp-service
result false
info bgp-service-template.xml:33 Element: 'bgp' only exists for ned-id: cisco-ios-cli-3.8:cisco-ios-cli-3.8
Hello -
Guillaume
gmuloche,
Thank you, that worked perfectly, I removed the conflicting NEDs and it worked right away.
I owe you a beer
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
