03-29-2020 05:36 PM - edited 03-29-2020 05:38 PM
I am trying to setup a NSO package for sol003 deployment of CSR VNF.
I read in the user guide that to allow access to the package artifacts the NFVO must support the /vnf_packages API - I checked this on my NSO by using
curl -X GET -u admin:admin http://<nso ip>:9191/vnfpkgm/v1/vnf_packages and it seems this is working
However whenever I invoke my service I get this error:
Aborted: External error in the NED implementation for device austx-lab-dev-esc-01-sol003: Prepare error: java.lang.Exception: [503] => Error during getAllPackages - 401 Unauthorized
I think I am missing some settings which provide username and password.
Here is my service call:
services csr_sol003 sol3_3 ciscoesc austx-lab-dev-esc-01-sol003 csr-authgroup csrgrp csr-hostname csr-os5 mgmt-net austx-nfv01-0099-prov-cml-SpectrumEnterprisem
admin@ncs(config-csr_sol003-sol3_3/ciscoesc/austx-lab-dev-esc-01-sol003)#
admin@ncs(config-csr_sol003-sol3_3/ciscoesc/austx-lab-dev-esc-01-sol003)# commit dry-run
cli {
local-node {
data devices {
device austx-lab-dev-esc-01-sol003 {
config {
etsisol003:vnf-instances {
+ vnf-instance austx-lab-dev-esc-01-sol003-vnf-info-sol3_3 {
+ d-id CSRsol003;
services {
+ csr_sol003 sol3_3 ciscoesc austx-lab-dev-esc-01-sol003 {
+ csr-authgroup csrgrp;
+ csr-hostname csr-os5;
+ mgmt-net austx-nfv01-0099-prov-cml-SpectrumEnterprise;
nfv {
+ vnf-info sol3_3 {
+ username admin;
+ vnfd CSRsol003;
+ vnfd-flavour vnf-csr;
+ instantiation-level medium;
+ vnfm austx-lab-dev-esc-01-sol003;
+ vnfm-type sol3;
+ vim-type openstack;
+ sol3-vnfm-type default-sol3;
+ vdu CSR {
+ managed;
+ image-name csr1000v-universalk9.03.17.02.S.156-1.S2-std;
+ flavour-name vnf-csr;
+ artifact iosxe_config.txt {
+ destination-name iosxe_config.txt;
+ url http://<ip>:4545/iosxe_config.txt;
+ variable ADMIN_PWD {
+ value [ admin ];
+ variable HOST_NAME {
+ value [ csr-os5 ];
+ variable USERNAME {
+ value [ admin ];
+ authgroup csrgrp;
+ host-key-verification-type none;
+ resource-orchestration {
+ vim nfvEsc {
+ vim-id nfv_esc;
+ vim-type OPENSTACK_V3;
+ access-params {
+ param password {
+ value ###;
+ type string;
+ param username {
+ value ciscoesc;
+ type string;
+ param vim_project {
+ value nfvoEsc;
+ type string;
+ interface-params {
+ param baseUrl {
+ value http://<ip>:5000/v3;
+ type string;
+ vnfd-connection-point mgmt {
+ network-name austx-nfv01-0099-prov-cml-SpectrumEnterprise;
Any hints how I can solve this?
Neetika
03-30-2020 06:58 AM
Hi Neetika,
You seem to be running into authentication failure for ESC --> NFVO communication, please ensure, ESC etsi production properties file has right username and password configuration (See below for more details). One of the common issues here is, using username vs userName in ESC etsi production properties. Please check ESC documentation for right configuration.
Hope this helps.
Anshu.
nfvo.apiRoot=<NSO IP>:
9090
nfvo.httpScheme=http
nfvo.username=admin123 (or nfvo.userName)
nfvo.password=admin123
03-30-2020 08:15 AM
Also, is there any particular reason why you're using SOL003 integration between NSO NFVO and ESC? For the case where there is no 3rd party VNFM then we would recommend to use NETCONF integration. SOL003 is still immature and incomplete, and although it works well in several customer deployments, we still believe integration would be more straightforward, cheaper and quicker using NETCONF.
04-02-2020 03:59 PM
Hi KJ,
The client has both Netcracker and ESC in their production environment. Different teams develop and support the packages using these VNFMs. The team I am working with is new to these and will be supporting in future. They right now want to learn the implementation using both NETCONF and sol003.
Neetika
03-30-2020 02:47 PM
Thanks Anshu,
I did check the ETSI-production.properties, as per ESC documentation it should be nfvo.username, I tried with both nfvo.username and nfvo.userName, it is not working either way. Here is my properties file:
[ciscoesc@austx-lab-dev-esc-01 etsi-vnfm]$ cat /opt/cisco/esc/esc_database/etsi-production.properties
# Rest username and password
security.user.name=admin
security.user.password=$1$rnkCB5$4Jf7v7xoK3JFpKmrXvM9O0
security.pam.service=
# Connection details for the NFVO
# apiRoot: The host and port (host:port)
# httpScheme: The http scheme (http or https)
nfvo.apiRoot=97.105.228.244:9191
nfvo.username=admin
nfvo.password=admin
# server.host: The IP address of this server. Only needs to be set if it has multiple ip addresses
server.host=97.105.228.252
http.enabled=true
https.enabled=false
Do you see any issues with this file? The curl request with user/password as admin/admin for packages work fine:
curl -X GET -u admin:admin http://97.105.228.244:9191/vnfpkgm/v1/vnf_packages
Neetika
03-30-2020 03:11 PM
Can you please share output of below command ? Also, please share NSO logs.
show nfv settings
Ideally, you should be able to see username passed to NFVO in access logs (under NSO logs).
Anshu.
03-30-2020 08:54 PM
Hi Anshu,
Here is my NFV settings:
admin@ncs(config)# show full-configuration nfv settings nfv settings image-server document-root /home/nmittal/nfvo
nfv settings etsi-sol3 server ip-address 97.105.228.244
nfv settings etsi-sol3 server port 9191
nfv settings etsi-sol3 server use-ssl false
nfv settings etsi-sol3 server verify-client-cert false
nfv settings etsi-sol3 server auth-enabled true
nfv settings etsi-sol3 server auth-types basic username admin
nfv settings etsi-sol3 server auth-types basic password $8$yo8zCkSla1zUDrVUAQdAkv4X8SaoLkPYt3y6Q+U0I6c=
nfv settings etsi-sol3 vnfm-behaviour vnfm-behaviour-override default-sol3
rpc-behaviour rpc include vim-info false
rpc-behaviour modify pre rpc false
rpc-behaviour modify post rpc false
grant scale authorise-grant true
admin@ncs(config)# show full-configuration devices device austx-lab-dev-esc-01-sol003
address 97.105.228.252
port 8250
ssh host-key ssh-rsa
key-data "......"
authgroup escsol3
device-type generic ned-id etsi-sol003-gen-1.13
read-timeout 420
trace raw
ned-settings etsi-sol003 connection ssl accept-any
ned-settings etsi-sol003 connection api-base-url /vnflcm/v1/
auth
credentials username admin
credentials password admin
type basic
param
tenant-id ciscoesc
base-url
vnf-instance /vnflcm/v1
sync
model vnf-instance
is-syncable true
model vnf-op
is-syncable true
model vnf-subscription
is-syncable true
only [ vnf-instance vnf-op vnf-subscription ]
proto
default http
number-of-retries 0
time-between-retry 1
ned-settings etsi-sol003 log-verbose true
ned-settings etsi-sol003 device model default-sol3
ned-settings etsi-sol003 flow
vnf-instance
instantiate auto true
terminate auto false
state admin-state unlocked
config
etsisol003:vnf-subscriptions vnf-subscription nfvo1
callbackUri http://97.105.228.244:9191/vnflcm/events
Also I have attached my access logs. Seems like it is getting admin as the username which is what I configured.
Please let me know if you get any clue what is wrong. Thank you.
03-31-2020 08:57 AM
I don't see ESC passing username, if you carefully check, PostmanRuntime/7.22.0 and curl/7.29.0 invocations (marked in bold) have username admin, all invocations from Apache-HttpClient/4.5.8 (ESC) don't pass admin user.
Can you please work with ESC team to get right configuration in place for version of ESC you are using?
Would request you again to share all NSO logs for easy trouble-shooing.
Anshu.
97.105.228.252 - - [30/Mar/2020:21:16:13 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 401 122 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
97.105.228.252 - - [30/Mar/2020:21:16:25 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 401 122 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
97.105.228.252 - - [30/Mar/2020:21:21:28 +0000] "POST /vnfpkgm/v1/subscriptions HTTP/1.1" 401 123 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
97.105.228.252 - - [30/Mar/2020:21:21:46 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 401 122 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
204.235.114.162 - admin [30/Mar/2020:21:23:52 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 200 1203 "-" "PostmanRuntime/7.22.0"
97.105.228.244 - admin [30/Mar/2020:21:46:50 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 200 5056 "-" "curl/7.29.0"
97.105.228.252 - - [31/Mar/2020:03:32:44 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 401 122 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
97.105.228.252 - - [31/Mar/2020:03:33:59 +0000] "GET /vnfpkgm/v1/vnf_packages HTTP/1.1" 401 122 "-" "Apache-HttpClient/4.5.8 (Java/1.8.0_222)"
03-31-2020 01:16 PM
Hi Anshu,
I am sharing the logs on email.
Neetika
04-02-2020 04:01 PM
