10-02-2019 11:39 PM - edited 10-02-2019 11:48 PM
I am facing IOSXR issue in getting/generating "no negotiation auto" command using NSO.
I am using the same leaf (via grouping) under IOS and IOSXE device with works fine, but for IOSXR devices, it does not works fine.
grouping Negotiation { container negotiation { tailf:info "Select autonegotiation mode"; leaf auto { tailf:info "Enable link autonegotiation"; tailf:cli-boolean-no; type boolean; } }
container IOS-XR {
when "/ncs:devices/ncs:device[ncs:name=current()/../../device]/ncs:platform/ncs:name='ios-xr'";
uses Interface-Choice-IOSXR;
uses Negotiation;
Below XML is generate in the format of NETCONF (for no negotiation auto).
But I am using CLI and XML. Please suggest.
admin@ncs(config-config)# admin@ncs(config-config)# cisco-ios-xr:interface GigabitEthernet 0/0/0/0 admin@ncs(config-if)# negotiation auto admin@ncs(config-if)# commit dry-run outformat native native { device { name IOS-XR data interface GigabitEthernet 0/0/0/0 negotiation auto exit } } admin@ncs(config-if)# commit dry-run outformat xml result-xml { local-node { data <devices xmlns="http://tail-f.com/ns/ncs"> <device> <name>IOS-XR</name> <config> <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> <GigabitEthernet> <id>0/0/0/0</id> <negotiation> <auto/> </negotiation> </GigabitEthernet> </interface> </config> </device> </devices> } } admin@ncs(config-if)# commit no-networking Commit complete. admin@ncs(config-if)# admin@ncs(config-if)# no negotiation auto admin@ncs(config-if)# admin@ncs(config-if)# admin@ncs(config-if)# commit dry-run outformat xml result-xml { local-node { data <devices xmlns="http://tail-f.com/ns/ncs"> <device> <name>IOS-XR</name> <config> <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> <GigabitEthernet> <id>0/0/0/0</id> <negotiation> <auto xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="delete"/> </negotiation> </GigabitEthernet> </interface> </config> </device> </devices> } } admin@ncs(config-if)# commit no-networking Commit complete. admin@ncs(config-if)#
BjronM~
10-04-2019 04:35 AM
10-04-2019 06:48 AM
There are a few points that are needed before somebody can start helping you
The following namespace is the one from the NED CLI for ios-xr:
So it looks like you are using the CLI NED - can you confirm this?
The first code snippet shared looks to be a service model where you have a grouping to activate or deactivate auto-negotiation. You mention that it works fine for IOS/IOS-XE - which seems to indicate that you have some service template or code that is used to map the service configuration to the device configuration - is it the case? In that case have you implemented similar logic in your template/code for IOS-XR devices? Maybe sharing what you have been trying, what works for ios and does not for iosxr (if it is ok) could help the community helping you.
If I had to guess I would say that what you are looking for in your template here is to use the tags (refer to NSO documenation on tags template in nso_development guide the "Templates / Basic Principles / Template tag operations" section ) and replace the XR part in your template with:
<negotiation> <auto tags="delete"/> </negotiation>
for the cases where the boolean in your grouping is false
10-06-2019 06:33 AM
Shouldn't this delete be part of your "pre-modification" logic? That is where you set what you expect as default configuration. You typically want to avoid "deletes" in FastMap.
Roque
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
