10-02-2019 11:39 PM - edited 10-02-2019 11:48 PM
I am facing IOSXR issue in getting/generating "no negotiation auto" command using NSO.
I am using the same leaf (via grouping) under IOS and IOSXE device with works fine, but for IOSXR devices, it does not works fine.
grouping Negotiation { container negotiation { tailf:info "Select autonegotiation mode"; leaf auto { tailf:info "Enable link autonegotiation"; tailf:cli-boolean-no; type boolean; } }
container IOS-XR {
when "/ncs:devices/ncs:device[ncs:name=current()/../../device]/ncs:platform/ncs:name='ios-xr'";
uses Interface-Choice-IOSXR;
uses Negotiation;
Below XML is generate in the format of NETCONF (for no negotiation auto).
But I am using CLI and XML. Please suggest.
admin@ncs(config-config)# admin@ncs(config-config)# cisco-ios-xr:interface GigabitEthernet 0/0/0/0 admin@ncs(config-if)# negotiation auto admin@ncs(config-if)# commit dry-run outformat native native { device { name IOS-XR data interface GigabitEthernet 0/0/0/0 negotiation auto exit } } admin@ncs(config-if)# commit dry-run outformat xml result-xml { local-node { data <devices xmlns="http://tail-f.com/ns/ncs"> <device> <name>IOS-XR</name> <config> <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> <GigabitEthernet> <id>0/0/0/0</id> <negotiation> <auto/> </negotiation> </GigabitEthernet> </interface> </config> </device> </devices> } } admin@ncs(config-if)# commit no-networking Commit complete. admin@ncs(config-if)# admin@ncs(config-if)# no negotiation auto admin@ncs(config-if)# admin@ncs(config-if)# admin@ncs(config-if)# commit dry-run outformat xml result-xml { local-node { data <devices xmlns="http://tail-f.com/ns/ncs"> <device> <name>IOS-XR</name> <config> <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> <GigabitEthernet> <id>0/0/0/0</id> <negotiation> <auto xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="delete"/> </negotiation> </GigabitEthernet> </interface> </config> </device> </devices> } } admin@ncs(config-if)# commit no-networking Commit complete. admin@ncs(config-if)#
BjronM~
10-04-2019 04:35 AM
10-04-2019 06:48 AM
There are a few points that are needed before somebody can start helping you
The following namespace is the one from the NED CLI for ios-xr:
So it looks like you are using the CLI NED - can you confirm this?
The first code snippet shared looks to be a service model where you have a grouping to activate or deactivate auto-negotiation. You mention that it works fine for IOS/IOS-XE - which seems to indicate that you have some service template or code that is used to map the service configuration to the device configuration - is it the case? In that case have you implemented similar logic in your template/code for IOS-XR devices? Maybe sharing what you have been trying, what works for ios and does not for iosxr (if it is ok) could help the community helping you.
If I had to guess I would say that what you are looking for in your template here is to use the tags (refer to NSO documenation on tags template in nso_development guide the "Templates / Basic Principles / Template tag operations" section ) and replace the XR part in your template with:
<negotiation> <auto tags="delete"/> </negotiation>
for the cases where the boolean in your grouping is false
10-06-2019 06:33 AM
Shouldn't this delete be part of your "pre-modification" logic? That is where you set what you expect as default configuration. You typically want to avoid "deletes" in FastMap.
Roque
