03-22-2019 11:21 PM
i am working on a service over Nokia BNGs and i cannot find a Nokia NED . is it not supported ?
Solved! Go to Solution.
03-28-2019 01:13 AM
If the Nokia/ALU BNG runs the Nokia SR OS then the alu-sr NED is the one to use. As usual, if there is a gap in the commands supported by the NED then you issue a request as per the process posted here on the NSO Developer Hub
03-25-2019 10:17 AM
There is nokia-nsp/alu-sr NEDs.
Not sure if they work with BNGs.
03-26-2019 12:41 PM - edited 03-26-2019 12:42 PM
i will check and send you results
03-26-2019 12:48 PM
i found alu NED but i cannot find nokia nsp or alu NED can work with Nokia too?
03-27-2019 01:41 PM
I think the alu-sr NED covers quite a few devices. I can't personally test since we don't have Nokia devices readily available.
03-28-2019 01:13 AM
04-02-2019 12:04 PM
Hi Ahmed,
We do have a "POC status" Nokia NSP NED that we are testing mainly for optical configuration. Please contact your Cisco sales contact to check if your usecase matches the POC NED.
Roque
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
