NACM setting up visibility of Yang leafs
navkuma4
I am looking suggestion or pointer on solution of NACM setting up the visibility for yang leafs.
For Ex. I have 2 leafs to treat based on type of user logs in – Basic or Advanced User.
    leaf basic {
      description "User level - Basic";
      tailf:info "User level as basic";
      type boolean;
      default true;
    leaf advanced {
      description "User level - Advanced";
      tailf:info "User level as Advanced";
      type boolean;
      default true;
Based on the type of user logs, we need to set the leaf accordingly.
We are going to use NSO4.6 version.
Jan Lindblad
Did you have a look at the "Authorization Examples" section in the NSO Admin Guide?
