NCS report; does not have a Network Element Driver registered
michelbijnsdorp
I'm trying to setup a NSO demo with a rather old Avaya 4k NED.  this driver is added to NSO and become active:
admin@ncs# show packages package oper-status
        PACKAGE
                   PROGRAM                                                        META     FILE
                   CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME           UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
avaya-4k       X   -        -              -        -        -        -           -        -      -
netsim devices_init stated:
   <device>
     <name>ava-4-0</name>
     <address>127.0.0.1</address>
     <port>10029</port>
     <ssh>
       <host-key>
         <algorithm>ssh-rsa</algorithm>
         <key-data>ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDC52JosNoAww63pGZWUfc4lowsR/2/ne8oxVOM1ig8P2H0nkWhGx6OpB9rmbBbf7j7eeaRzBzLiIJp25nq3jJXJODxkObSqtqKODRPpCkQ
y+TmXlTeb4QgIFHkNYaCfIpObBo0q5CReExyFvbCeeZO6uQNd86t/fYA69Vr78ln94YThdL9P4+SywsaW2BE4bZaIFP235L7Bjxg/LTIT5TzKOcZV/CqJKi7dJlTrkcJHyu5sS+dyp+PmTuLC7+gQytDlvQD4Ek0npq
tbp6mfVyZ8B/hN8RUaw4uoBymok3Iy+QKBeWoZ6zjzym19HiJXFwC</key-data>
       </host-key>
     </ssh>
     <state>
       <admin-state>unlocked</admin-state>
     </state>
     <authgroup>default</authgroup>
     <device-type>
       <cli>
         <ned-id xmlns:avaya-4k-id="http://tail-f.com/ned/avaya-4k-id">avaya-4k-id:avaya-4k</ned-id>
       </cli>
     </device-type>
   </device>
   <device>
netsim dir stated : netsim list
name=ava-4-0 netconf=12029 snmp=11029 ipc=5017 cli=10029 dir=/home/nso/LabDir45/netsim/ava-4-/ava-4-0
from the ncs admin console I tried to add de device ;
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# devices device ava-4-0
admin@ncs(config-device-ava-4-0)# address 127.0.0.1 port 10029
admin@ncs(config-device-ava-4-0)# device-type cli ned-id avaya-4k protocol ssh
admin@ncs(config-device-ava-4-0)# authgroup default
admin@ncs(config-device-ava-4-0)# state admin-state unlocked
admin@ncs(config-device-ava-4-0)# ssh fetch-host-keys ?
Possible completions:
  <cr>
result unchanged
fingerprint {
    algorithm ssh-rsa
    value f4:a7:64:d2:0c:98:0c:5e:75:39:09:a3:c1:16:f3:a2
admin@ncs(config-device-ava-4-0)# commit
Commit complete.
admin@ncs(config-device-ava-4-0)# sync-from
result false
info Device ava-4-0 does not have a Network Element Driver registered
The question is why do I get these errors that the NED is not registered and how can I fix this ?
Any reponse in this matter is appreciated ?
With kind regards Michel Bijnsdorp
michelbijnsdorp
The devel.log reports the following:
<DEBUG> 11-Jul-2018::10:46:11.706 NSO ncs[9005]: ncs Requestor {'sync-from',91,<0.3296.0>} tries to acquire lock for device <<"ava-4-0">>
<INFO> 11-Jul-2018::10:46:11.706 NSO ncs[9005]: ncs device ava-4-0: sync-from...
<INFO> 11-Jul-2018::10:46:11.708 NSO ncs[9005]: ncs device ava-4-0: connect: device connect...
<INFO> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs device ava-4-0: connect: send NED connect
<ERR> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs cli ned-id 'avaya4k-id:avaya-4k' not registered by user code. The following ned-ids are registered: ['avaya4k-id:avaya4k',
        'alu-sr-id:alu-sr',
        'ios-id:cisco-ios',
        'avaya8k-id:avaya8k',
        'cisco-ios-xr-id:cisco-ios-xr',
        'bigip:f5-bigip']
<INFO> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs device ava-4-0: connect: device connect error
<INFO> 11-Jul-2018::10:46:11.710 NSO ncs[9005]: ncs device ava-4-0: sync-from error
<DEBUG> 11-Jul-2018::10:46:11.710 NSO ncs[9005]: ncs Device <<"ava-4-0">> is unlocked
While device ava-4-0  has NED-ID: avaya4k ???
Cisco support answered that this Avaya NED is to old and therefore this error message was generated.
