NCS report; does not have a Network Element Driver registered
michelbijnsdorp
I'm trying to setup a NSO demo with a rather old Avaya 4k NED.  this driver is added to NSO and become active:
admin@ncs# show packages package oper-status
        PACKAGE
                   PROGRAM                                                        META     FILE
                   CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME           UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
avaya-4k       X   -        -              -        -        -        -           -        -      -
netsim devices_init stated:
   <device>
     <name>ava-4-0</name>
     <address>127.0.0.1</address>
     <port>10029</port>
     <ssh>
       <host-key>
         <algorithm>ssh-rsa</algorithm>
         <key-data>ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDC52JosNoAww63pGZWUfc4lowsR/2/ne8oxVOM1ig8P2H0nkWhGx6OpB9rmbBbf7j7eeaRzBzLiIJp25nq3jJXJODxkObSqtqKODRPpCkQ
y+TmXlTeb4QgIFHkNYaCfIpObBo0q5CReExyFvbCeeZO6uQNd86t/fYA69Vr78ln94YThdL9P4+SywsaW2BE4bZaIFP235L7Bjxg/LTIT5TzKOcZV/CqJKi7dJlTrkcJHyu5sS+dyp+PmTuLC7+gQytDlvQD4Ek0npq
tbp6mfVyZ8B/hN8RUaw4uoBymok3Iy+QKBeWoZ6zjzym19HiJXFwC</key-data>
       </host-key>
     </ssh>
     <state>
       <admin-state>unlocked</admin-state>
     </state>
     <authgroup>default</authgroup>
     <device-type>
       <cli>
         <ned-id xmlns:avaya-4k-id="http://tail-f.com/ned/avaya-4k-id">avaya-4k-id:avaya-4k</ned-id>
       </cli>
     </device-type>
   </device>
   <device>
netsim dir stated : netsim list
name=ava-4-0 netconf=12029 snmp=11029 ipc=5017 cli=10029 dir=/home/nso/LabDir45/netsim/ava-4-/ava-4-0
from the ncs admin console I tried to add de device ;
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# devices device ava-4-0
admin@ncs(config-device-ava-4-0)# address 127.0.0.1 port 10029
admin@ncs(config-device-ava-4-0)# device-type cli ned-id avaya-4k protocol ssh
admin@ncs(config-device-ava-4-0)# authgroup default
admin@ncs(config-device-ava-4-0)# state admin-state unlocked
admin@ncs(config-device-ava-4-0)# ssh fetch-host-keys ?
Possible completions:
  <cr>
result unchanged
fingerprint {
    algorithm ssh-rsa
    value f4:a7:64:d2:0c:98:0c:5e:75:39:09:a3:c1:16:f3:a2
admin@ncs(config-device-ava-4-0)# commit
Commit complete.
admin@ncs(config-device-ava-4-0)# sync-from
result false
info Device ava-4-0 does not have a Network Element Driver registered
The question is why do I get these errors that the NED is not registered and how can I fix this ?
Any reponse in this matter is appreciated ?
With kind regards Michel Bijnsdorp
michelbijnsdorp
The devel.log reports the following:
<DEBUG> 11-Jul-2018::10:46:11.706 NSO ncs[9005]: ncs Requestor {'sync-from',91,<0.3296.0>} tries to acquire lock for device <<"ava-4-0">>
<INFO> 11-Jul-2018::10:46:11.706 NSO ncs[9005]: ncs device ava-4-0: sync-from...
<INFO> 11-Jul-2018::10:46:11.708 NSO ncs[9005]: ncs device ava-4-0: connect: device connect...
<INFO> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs device ava-4-0: connect: send NED connect
<ERR> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs cli ned-id 'avaya4k-id:avaya-4k' not registered by user code. The following ned-ids are registered: ['avaya4k-id:avaya4k',
        'alu-sr-id:alu-sr',
        'ios-id:cisco-ios',
        'avaya8k-id:avaya8k',
        'cisco-ios-xr-id:cisco-ios-xr',
        'bigip:f5-bigip']
<INFO> 11-Jul-2018::10:46:11.709 NSO ncs[9005]: ncs device ava-4-0: connect: device connect error
<INFO> 11-Jul-2018::10:46:11.710 NSO ncs[9005]: ncs device ava-4-0: sync-from error
<DEBUG> 11-Jul-2018::10:46:11.710 NSO ncs[9005]: ncs Device <<"ava-4-0">> is unlocked
While device ava-4-0  has NED-ID: avaya4k ???
Cisco support answered that this Avaya NED is to old and therefore this error message was generated.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
