netsim sync failing with timeout
srisikha@cisco.com
sync-result {
device S-Test
result false
info Failed to connect to device S-Test: connection refused: NEDCOM CONNECT: The kexTimeout (20000 ms) expired. in new state
Any help to fix this appreciated
kiran kotari
kiran kotari
Hi srisikha,
I have answered the question here, please have a look.
https://community.cisco.com/t5/nso-developer-hub-discussions/netsim-devices-oboarding-issue/m-p/4120316#M5483
-Kiran
Hi Kiran,
Thanks- just some background - we have a product called SAE - Secure agile exchange which is on top of NSO/NFVO and it has GUI and we are adding a device from that GUI. Looks like that device is not present on NSO device list and when we did a Sync on it we getting a timeout -instead of device not present. Thanks - we will add the device to netsim.
swarudka
Before sync from please check the device is present on netsim or not, the device should be alive and started in ncs
to check same use this command >> ncs-netsim is-alive
if it is not present there, follow below steps to add same and sync it
1.create netsim device >> i have added device as TEST_ASA1
#ncs-netsim add-device packages/cisco-asa-cli-6.9 TEST_ASA1
DEVICE TEST_ASA1 CREATED
2.start the netsim device
# ncs-netsim start TEST_ASA1
DEVICE TEST_ASA1 OK STARTED
3. To check if it is added or not
# ncs-netsim list
we need to fetch ssh key to avoid sync from error
4. Fetch SSH key for the device
admin@ncs# devices device TEST_ASA1 ssh fetch-host-keys
5. run below command to sync
admin@ncs# devices device TEST_ASA1 sync-from
To check the device is sync or not run below command
#request devices fetch-ssh-host-keys
This is how i have resolved the issue with the help of kiran
Thank you Kiran:)
