No Packages in NSO
previousqna
Level 5
Level 5
Hi all,
I have a local install
JABELK-M-D3BK:neds jabelk$ ls -la
total 8
drwxr-xr-x  3 jabelk  staff  102 Apr 12 08:08 .
drwxr-xr-x  4 jabelk  staff  136 Apr 12 08:08 ..
lrwxr-xr-x  1 jabelk  staff   53 Apr 12 08:08 cisco-ios -> /Users/jabelk/ncs-all/ncs-4.4/packages/neds/cisco-ios
JABELK-M-D3BK:neds jabelk$ pwd
/Users/jabelk/ncs-all/ncs-run/packages/neds
JABELK-M-D3BK:cisco-ios jabelk$ ls -la
total 424
drwxr-xr-x  12 jabelk  staff     408 Apr 11 18:23 .
drwxr-xr-x  16 jabelk  staff     544 Apr 11 18:16 ..
-rw-r--r--   1 jabelk  staff  174264 Apr  6 23:34 CHANGES
-rw-r--r--   1 jabelk  staff     166 Apr  6 23:34 LICENSE
-rw-r--r--   1 jabelk  staff   25635 Apr  6 23:34 README
-rw-r--r--   1 jabelk  staff     686 Apr  6 23:37 build-meta-data.xml
drwxr-xr-x   7 jabelk  staff     238 Apr  6 23:36 load-dir
drwxr-xr-x  24 jabelk  staff     816 Apr  6 23:37 netsim
-rw-r--r--   1 jabelk  staff    1255 Apr 11 18:23 package-meta-data.xml
drwxr-xr-x   3 jabelk  staff     102 Apr  6 23:36 private-jar
drwxr-xr-x   3 jabelk  staff     102 Apr  6 23:36 shared-jar
drwxr-xr-x   8 jabelk  staff     272 Apr 11 18:23 src
total 89368
drwxr-xr-x   6 jabelk  staff       204 Apr 11 22:22 ..
-rw-r--r--@  1 jabelk  staff      6148 Apr 11 18:16 .DS_Store
-rw-r--r--   1 jabelk  staff      1792 Apr  7 08:27 README.signature
drwxr-xr-x  13 jabelk  staff       442 Mar 21 07:57 a10-acos
drwxr-xr-x  12 jabelk  staff       408 Apr 11 18:23 cisco-ios
drwxr-xr-x  12 jabelk  staff       408 Mar 21 07:57 cisco-ios-old
drwxr-xr-x  13 jabelk  staff       442 Mar 21 07:57 cisco-iosxr
drwxr-xr-x  13 jabelk  staff       442 Mar 21 07:57 cisco-nx
-rw-r--r--   1 jabelk  staff     10696 Nov 25 07:25 cisco_x509_verify_release.py
drwxr-xr-x  13 jabelk  staff       442 Mar 21 07:57 dell-ftos
drwxr-xr-x  10 jabelk  staff       340 Mar 21 07:57 juniper-junos
-rw-r--r--@  1 jabelk  staff  22847968 Apr 11 18:14 ncs-4.4-cisco-ios-5.1.2.signed.bin
-rw-r--r--   1 jabelk  staff  22871442 Apr  6 21:37 ncs-4.4-cisco-ios-5.1.2.tar.gz
-rw-r--r--   1 jabelk  staff       256 Apr  7 08:27 ncs-4.4-cisco-ios-5.1.2.tar.gz.signature
-rw-r--r--   1 jabelk  staff      1383 Nov 25 07:25 tailf.cer
here is the result of the ios NED make:
JABELK-M-D3BK:ncs-run jabelk$ cd /Users/jabelk/ncs-all/ncs-4.4/packages/neds/cisco-ios
JABELK-M-D3BK:cisco-ios jabelk$ cd src/
JABELK-M-D3BK:src jabelk$ ls -la
total 24
drwxr-xr-x   8 jabelk  staff   272 Apr 11 18:23 .
drwxr-xr-x  12 jabelk  staff   408 Apr 11 18:23 ..
-rw-r--r--   1 jabelk  staff  2791 Apr  6 23:34 Makefile
drwxr-xr-x   5 jabelk  staff   170 Apr  6 23:36 java
drwxr-xr-x   3 jabelk  staff   102 Apr  6 23:34 ncsc-out
-rw-r--r--   1 jabelk  staff  1112 Apr 11 18:23 ned-data-snippet.fxs
-rw-r--r--   1 jabelk  staff  2452 Apr  6 23:34 ned-yang-filter.mk
drwxr-xr-x   7 jabelk  staff   238 Apr  6 23:34 yang
JABELK-M-D3BK:src jabelk$ make
YANG COMPILER SUPPORTS ned-data. Disabling commit-queue lock from package-meta-data.xml
/Users/jabelk/ncs-all/ncs-4.4/bin/ncsc --ncs-compile-module tmp-yang/tailf-ned-cisco-ios.yang \
                --ncs-device-dir ncsc-out \
    --ncs-skip-statistics \
                --ncs-device-type cli-ned \
   cp ncsc-out/modules/fxs/tailf-ned-cisco-ios.fxs ../load-dir
tmp-yang/tailf-ned-cisco-ios.yang:55104: warning: the path expression ../../vlan-list/name for 'tailf:cli-diff-dependency' is a circular dependency
tmp-yang/tailf-ned-cisco-ios.yang:57164: warning: when tailf:cli-drop-node-name is given, it is recommended that tailf:cli-suppress-mode is used in combination. using tailf:cli-drop-nodename in a list child without using tailf:cli-suppress-mode on the list, might lead to confusing behaviour, where the user enters the submode without being able to give further configuration.
tmp-yang/tailf-ned-cisco-ios.yang:65242: warning: when tailf:cli-drop-node-name is given, it is recommended that tailf:cli-suppress-mode is used in combination. using tailf:cli-drop-nodename in a list child without using tailf:cli-suppress-mode on the list, might lead to confusing behaviour, where the user enters the submode without being able to give further configuration.
augmented/tailf-ned-cisco-ios@2017-04-07.yang:101340: warning: when tailf:cli-sequence-commands is given, it is recommended that tailf:cli-compact-syntax is used in combination. or that tailf:cli-hide-in-submode is given in at least one of the child nodes
augmented/tailf-ned-cisco-ios@2017-04-07.yang:104617: warning: when tailf:cli-drop-node-name is given, it is recommended that tailf:cli-suppress-mode is used in combination. using tailf:cli-drop-nodename in a list child without using tailf:cli-suppress-mode on the list, might lead to confusing behaviour, where the user enters the submode without being able to give further configuration.
augmented/tailf-ned-cisco-ios@2017-04-07.yang:112869: warning: when tailf:cli-drop-node-name is given, it is recommended that tailf:cli-suppress-mode is used in combination. using tailf:cli-drop-nodename in a list child without using tailf:cli-suppress-mode on the list, might lead to confusing behaviour, where the user enters the submode without being able to give further configuration.
/Users/jabelk/ncs-all/ncs-4.4/bin/ncsc --java-disable-prefix --exclude-enums --fail-on-warnings --java-package com.tailf.packages.ned.ios.namespaces --emit-java java/src/com/tailf/packages/ned/ios/namespaces/tailfCiscoIos.java ncsc-out/modules/fxs/tailf-ned-cisco-ios.fxs
cd java && ant -q all
    [javac] warning: [options] bootstrap class path not set in conjunction with -source 1.6
    [javac] 1 warning
BUILD SUCCESSFUL
Total time: 1 second
pushd ../netsim && /Library/Developer/CommandLineTools/usr/bin/make all && popd
~/ncs-all/ncs-4.4/packages/neds/cisco-ios/netsim ~/ncs-all/ncs-4.4/packages/neds/cisco-ios/src
make[1]: Nothing to be done for `all'.
rm -f *.yang
rm -rf tmp-yang
admin@ncs# show packages
% No entries found.
admin@ncs# packages reload
% No entries found.
admin@ncs#
JABELK-M-D3BK:ncs-run jabelk$ ncs --with-package-reload
JABELK-M-D3BK:ncs-run jabelk$ ncs --version
4.4
JABELK-M-D3BK:ncs-run jabelk$ ncs_cli -u admin -C
admin connected from 127.0.0.1 using console on JABELK-M-D3BK
% No entries found.
admin@ncs#
I do not understand why I still cannot see any packages in my fresh install, when I followed the steps for install here:
https://wwwin-github.cisco.com/pages/nsopl/doc/html/nso_installation_guide/ch02s02.html
and
Installation of NCS/NSO Natively on a MAC - Cisco
From what I can tell, it should be picking up the new packages:
https://wwwin-github.cisco.com/pages/nsopl/doc/html/nso_admin_guide/ug.package_mgmt.overview.html
from the default
/ncs-config/load-path
which has:
<load-path>
    <dir>./packages</dir>
    <dir>${NCS_DIR}/etc/ncs</dir>
    <!-- To disable northbound snmp altogether -->
    <!-- comment out the path below -->
    <dir>${NCS_DIR}/etc/ncs/snmp</dir>
  </load-path>
are settings being used, the linked directory into packages should show up, correct?
previousqna
Level 5
Level 5
figured it out, I was linking the packages under a NED folder to mirror the 4.4 install:
total 8
when what I needed to do was link the cisco-ios package under "packages" directly, with no NED sub folder, NSO must have hard coded to look for it without NED folder, which is confusing since the install directory has the sub-folder:
JABELK-M-D3BK:packages jabelk$ ls -l
total 8
drwxrwxrwx  3 jabelk  staff  102 Apr 12 08:08 neds
JABELK-M-D3BK:packages jabelk$ pwd
So the above bolded linked cisco-ios package (NED) under no subfolder showed up in the packages reload, but if under the NED sub-folder, it was never showing up.
Just to be clear, there should be no neds folder in the packages :
total 8
previousqna
Level 5
Level 5
total 8
total 8
total 8
