06-13-2017 10:18 AM - edited 03-01-2019 03:52 AM
Hi!
Does NSO support the provisioning of a static route inside a vrf when trying to configure an IOS XR device?
I've tried this in NSO 4.3 and the regular XR configuration path/commands:
router static
vrf {name}
are not present (looks like) . There is another configuration path that does appear, but when applied the router doesn't like it:
device devices { | ||
2 | device XR-1 { | device XR-1 { |
3 | config { | config { |
4 | cisco-ios-xr:ip { | cisco-ios-xr:ip { |
5 | route { | route { |
6 | vrf { | vrf { |
7 | + name test; | |
8 | + dest 10.0.0.1; | |
9 | + dest-mask 255.255.255.255; | |
10 | + forwarding-address 172.16.1.1; | |
11 | } | } |
I just installed NSO 4.4 to see if this has changed, but since it has not, I thought I'd ask here if it's even supported.
c.
Solved! Go to Solution.
06-13-2017 10:33 AM
The NED versions that come with NSO are pretty minimal, and only for use with the demos and labs in the examples directory. Please use a recent NED version.
Cheers,
KJ.
06-13-2017 10:28 AM
Which version of the IOS XR NED are you using? The current latest is 6.0.
You could try to put the configuration on the device and do a sync-from, and have a look at the resulting config in NSO?
Cheers,
KJ.
06-13-2017 10:30 AM
Well, I honestly don't know. I've been using whatever comes with NSO4.3 up until now. I will run your suggestion and either post output or solution here, if fixed.
Thanks a lot!
c.
06-13-2017 10:33 AM
Cheers,
KJ.
06-13-2017 10:36 AM
Will look into the docs to see how to do it.
Where do you get the newer NEDs, though?
06-14-2017 02:42 PM
Hi, Kjetil:
I have the new (XR) NEDS now, I did a make on them and copied it to my running netsim environment, just like I first did when I setup my local NSO installation, but when I try to run netsim, I get the following error message:
./ietf-netconf-acm.fxs: Must be recompiled!
yan@nso4:~/nso-run$ ncs-netsim start
DEVICE IOS-0 OK STARTED
DEVICE IOS-1 OK STARTED
Bad configuration: confd.conf:0: ./ietf-netconf-acm.fxs: Must be recompiled!
Daemon died status=21
DEVICE XR-0 FAIL
DEVICE XR-1 FAIL
DEVICE XR-2 FAIL
yan@nso4:~/nso-run$
Can you help?
c.
06-14-2017 03:45 PM
just re-create your NETSIM devices. Looks like there is a version mismatch from when they were originally created to your current version.
ncs-netsim delete-network
and then
ncs-netsim create-network ...... (add your commands)
Roque
06-14-2017 04:21 PM
Thank you very much for your reply, Roque. I did this, actually, and no luck. I even cleaned my nso-run directory completely and stryed from scratch, no luck.
I'd like to add I reinstalled NSO4.4, cleaned the whole thing. started from scratch, but even when I try to start netsim I get:
yan@nso4:~/nso-run$ ls
netsim packages
DEVICE XR-0 FAIL
DEVICE XR-1 FAIL
DEVICE XR-2 FAIL
yan@nso4:~/nso-run$
I'm not sure if using a local-install has anything to do with this. Any ideas?
Thanks!
c.
06-15-2017 09:16 AM
This last issue (NED upgrade) has been solved and documented here:
Re: [Problem with NSO NED upgrade]
As for the static route problem, upgrading to a newer version of NED definitely did the trick. Thanks, KJ!
06-13-2017 10:35 AM
Just configured this static route:
RP/0/0/CPU0:XR-0-PE#show run router static
Tue Jun 13 09:26:09.855 UTC
router static
vrf mgmt
address-family ipv4 unicast
0.0.0.0/0 172.16.1.1
But when I do a sync-from, NSO doesn't pull it from the router. Basically no 'router static' configuration path:
admin@ncs> request devices device XR-0 sync-from
result true
[ok][2017-06-13 12:32:38]
admin@ncs> show configuration devices device XR-0
address 172.16.1.10;
port 22;
ssh {
host-key ssh-rsa {
key-data "AAAAB3NzaC1yc2EAAAADAQABAAABAQC12PbaBSkNvWEzBE4HE/ekDACNPXy+2tZRKFAfYpNu\n/zP4fhi0NNEQZRG3y6CFCBQyKgDTJ+fGvJFpATC7L4KyczyxWupKDKFwA9dOiPf827vHeEq0\n+PxrsadX9bBbqwXwSqhsZf67gUbbyVCyMPOcycbMcdrcIWi4avQbIuG05PAwL63QH9mgVg+X\nnuxaF/Hm8pFcIc8eKhxJ2opgRwoCeBq76OnmI24azrnpUX5ZsbKHQS0LApcjVViouiJ1JhM1\nWcMiwdoYK50hRpn8lXeuGSOi+cdGf3i/6LeTo8Nk2SOB94dRaLiYOac78hMoLGFNnwvsMWd8\nZGJal7emPNr7";
authgroup mygroup;
device-type {
cli {
ned-id cisco-ios-xr;
state {
admin-state unlocked;
config {
cisco-ios-xr:hostname XR-0-PE;
cisco-ios-xr:vrf {
vrf-list mgmt {
address-family {
ipv4 {
unicast;
cisco-ios-xr:domain {
name mnet.com.mx;
cisco-ios-xr:mpls {
ldp {
router-id 10.0.0.10;
interface GigabitEthernet0/0/0/0.1;
cisco-ios-xr:ssh {
server {
vrf default;
vrf mgmt;
cisco-ios-xr:interface {
Loopback 0 {
ipv4 {
address {
ip 10.0.0.10;
MgmtEth 0/0/CPU0/0 {
ipv4 {
address {
ip 172.16.1.10;
mask 255.255.255.0;
vrf mgmt;
GigabitEthernet 0/0/0/0.1 {
ipv4 {
address {
ip 10.10.11.10;
mask 255.255.255.0;
encapsulation {
dot1q {
1011;
cisco-ios-xr:router {
ospf 1 {
area 0 {
interface GigabitEthernet0/0/0/0.1 {
network point-to-point;
mtu-ignore {
enable;
interface Loopback0 {
passive {
enable;
bgp {
bgp-no-instance 1 {
address-family {
ipv4 {
unicast;
vpnv4 {
unicast;
[ok][2017-06-13 12:32:56]
admin@ncs>
