Problem in NED make on NSO 4.5
mowahba
I just installed NSO 4.5 and ran into this error when I was trying to make the NEDs for IOS, XR & JUNOS
[root@localhost neds]# cd cisco-ios
[root@localhost cisco-ios]# cd src
[root@localhost src]# ll
total 16
drwxr-xr-x. 4 root root 4096 Nov 30 19:01 java
-rw-r--r--. 1 root root 2175 Nov 30 19:01 Makefile
drwxr-xr-x. 3 root root 4096 Nov 30 19:01 ncsc-out
drwxr-xr-x. 2 root root 4096 Nov 30 19:01 yang
[root@localhost src]# make
Makefile:17: /src/ncs/build/include.ncs.mk: No such file or directory
/bin/sh: - : invalid option
Usage: /bin/sh [GNU long option] [option] ...
  /bin/sh [GNU long option] [option] script-file ...
GNU long options:
  --debug
  --debugger
  --dump-po-strings
  --dump-strings
  --help
  --init-file
  --login
  --noediting
  --noprofile
  --norc
  --posix
  --protected
  --rcfile
  --rpm-requires
  --restricted
  --verbose
  --version
Shell options:
  -irsD or -c command or -O shopt_option (invocation only)
  -abefhkmnptuvxBCHP or -o option
make: *** No rule to make target `/src/ncs/build/include.ncs.mk'.  Stop.
any guidance ?
Jan Lindblad
You forgot to source the ncsrc file of the NSO version you intend to use.
Say I want to use NSO 4.5.1 and have it installed in ~/nso/4.5.1, I'd run this command in a bash-family shell:
. ~/nso/4.5.1/ncsrc
Then retry your build.
mowahba
It works now , thanks Jan !
