Problem with configuring NSO device-type cli ned-id
wesleyderks
Community Member
I am trying to configure the NSO in the lab NSO Fundamentals, but I get stuck when I add the device edge-sw01. When I follow the steps one off the commands isn't recognized. This are the steps what on the site is writen:
devices device edge-sw01
address 10.10.20.172
authgroup labadmin
device-type cli ned-id cisco-ios-cli-6.44
device-type cli protocol telnet
ssh host-key-verification none commit
All the commands are accepted, only device-type cli ned-id cisco-ios-cli-6.44 isn't possible to add. Also I tryed the load merge command from a copy off the config from 10.10.20.49, but I get the same error on line 5 what is the same command.
The only 3 options what I have got are these:
admin@ncs(config-device-edge-sw01)# device-type cli ned-id ?
Description: The NED Identity
Possible completions:
[lsa-netconf] lsa-netconf netconf snmp
What I am doing wrong? Hopefully anyone has a answer for my problem, thanks anyway for reading
Gr Wesley
So, the ncs-setup command will create a new NSO 'run-time' directory to use with a NSO 'local' install.
Generally the run-time directory is created outside of the NSO product install directory.
This command above (I didn't see this command in the lab example):
ncs-setup --dest ${NCS_DIR}/packages/neds
created a new directory called 'neds' as a NSO run-time directory, overwriting the NEDs provided with your NSO distribution.
Subsequent linking to neds in that directory which are no longer there - so your links are going nowhere so NSO has nothing to load.
So you'll need to re-install NSO to get those NEDs back and then proceed as follows:
I keep a directory called Projects where I put all my NSO run-time directories, say it's at ~/Projects:
$ cd ~/Projects
Projects$ source ~/NCS/releases/nso-5.3.1/ncsrc
Projects$ echo $NCS_DIR
/Users/lmanor/NCS/releases/nso-5.3.1
Projects$
Projects$ ncs-setup --package $NCS_DIR/packages/neds/cisco-ios-cli-3.8 --package $NCS_DIR/packages/neds/cisco-nx-cli-3.0 --package $NCS_DIR/packages/neds/cisco-iosxr-cli-3.5 --package $NCS_DIR/packages/neds/cisco-asa-cli-6.6 --dest nso-runtime
Projects$ cd nso-runtime
nso-runtime$ ls
README.ncs logs ncs-cdb ncs.conf packages scripts state
nso-runtime$ cd packages/
packages$ ls -altr
total 0
lrwxr-xr-x 1 lmanor staff 68 Sep 25 12:07 cisco-ios-cli-3.8 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-ios-cli-3.8
lrwxr-xr-x 1 lmanor staff 67 Sep 25 12:07 cisco-nx-cli-3.0 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-nx-cli-3.0
lrwxr-xr-x 1 lmanor staff 70 Sep 25 12:07 cisco-iosxr-cli-3.5 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-iosxr-cli-3.5
lrwxr-xr-x 1 lmanor staff 68 Sep 25 12:07 cisco-asa-cli-6.6 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-asa-cli-6.6
drwxr-xr-x 6 lmanor staff 192 Sep 25 12:07 .
drwxr-xr-x 9 lmanor staff 288 Sep 25 12:07 ..
packages$ ls cisco-asa-cli-6.6
CHANGES LICENSES.nedcom build-meta-data.xml netsim private-jar src
LICENSE README load-dir package-meta-data.xml shared-jar
Then from the nso run-time directory, start NSO:
packages$ cd ..
nso-runtime$ ncs
nso-runtime$ ncs_cli -u admin
admin connected from 127.0.0.1 using console on LMANOR-M-24MR
admin@ncs>
admin@ncs> show packages package oper-status
PACKAGE
PROGRAM META FILE
CODE JAVA PYTHON BAD NCS PACKAGE PACKAGE CIRCULAR DATA LOAD ERROR
NAME UP ERROR UNINITIALIZED UNINITIALIZED VERSION NAME VERSION DEPENDENCY ERROR ERROR INFO
cisco-asa-cli-6.6 X - - - - - - - - - -
cisco-ios-cli-3.8 X - - - - - - - - - -
cisco-iosxr-cli-3.5 X - - - - - - - - - -
cisco-nx-cli-3.0 X - - - - - - - - - -
8 Replies 8
lmanor
It looks like you may not have the cisco-ios-cli-6.44 NED package (or any other NED for that matter) loaded into NSO.
If you show packages what is loaded into NSO:
From operational cli mode:
admin@ncs# show packages package oper-status
Hello Imanor
Thanks for the reply. It seems that is the problem that the NED packages aren't loaded in the NSO
% No entries found.
I thought that I loaded the NED packages in a early state with these commands
ncs-setup --package nso/packages/neds/cisco-ios-cli-6.44 \
> --package nso/packages/neds/cisco-nx-cli-5.15 \
> --package nso/packages/neds/cisco-iosxr-cli-7.20 \
> --package nso/packages/neds/cisco-asa-cli-6.8 \
> --dest nso-instance
After these commands I saw in the directory nso-instance these logical links created
lrwxrwxrwx 1 developer docker 26 Sep 25 04:48 cisco-asa-cli-6.8 -> packages/cisco-asa-cli-6.8
lrwxrwxrwx 1 developer docker 27 Sep 25 04:48 cisco-ios-cli-6.44 -> packages/cisco-ios-cli-6.44
lrwxrwxrwx 1 developer docker 29 Sep 25 04:48 cisco-iosxr-cli-7.20 -> packages/cisco-iosxr-cli-7.20
lrwxrwxrwx 1 developer docker 26 Sep 25 04:48 cisco-nx-cli-5.15 -> packages/cisco-nx-cli-5.15
Did I forget something or isn't the configuration correct? I follewed 3 times the steps, but I don't see what is wrong.
$ cd ~/Projects
Projects$
nso-runtime$ ls
packages$ ls -altr
total 0
packages$ cd ..
nso-runtime$ ncs
admin@ncs>
PACKAGE
PROGRAM META FILE
Thanks for the reply, at this moment there is a maintenance window, so I will try the solution after the weekend
greatings Wesley
Thanks Imanor,
I tryed the steps again today and everything is working fine
Gr Wesley
RiekCyber
Frequent Visitor
Frequent Visitor
You just have to copy the NED package you need from  ./ncs-6.0/packages/neds/ to  ./ncs-run/packages/
Then You have to reload the package in the cli with the command  admin@ncs# packages reload
>> https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2019/pdf/LABSPG-2442-LG.pdf .
There is no NED package in the ncs-run directory by default.
Truly yours,
Thanks your suggestion did it for me. Have a great day!
Jesus Illescas
If you are starting with NSO, I highly recommend to take a look at these learning labs.
- https://developer.cisco.com/learning/labs/learn-nso-with-netsim/
- https://developer.cisco.com/learning/tracks/get_started_with_nso/
They go step-by-step to getting started with NSO. There you can find detailed guides and you can practice with a live environment directly on the web browser.
The NSO you can find there is based on the official NSO container.
Let us know any suggestion, we are actively update them.
