resource-manager id pool scalability
ryan-hitch
Level 4
Level 4
Looking for some suggestions for deployment of an MPLS VPN service for a relatively small ISP (~200 sites).
The plan is to use resource-manager id-allocator to maintain globally unique MPLS VPN IDs (single id pool), and then tie these globally unique VPN IDs to site-unique VLAN ID that will require a VLAN ID pool per site (~200 pools). Is this feasible with the resource-manager id-pool package, or am I asking for trouble?
rogaglia
These numbers are very small compared to what NSO can perform. Maybe the only missing parameter is how many transactions per hour you are expecting in average hours (normal load) and in burst hours (busy hours).
Roque
rogaglia
Roque
