Bookmark
Subscribe
120
Removing opendns updater for mac
bootstrapjesse
Greetings. Does anyone know how to remove the opendns updater for Mac.  Using OSX 10.11.5. I'm trying to do some trouble shooting. I cant seem to disable login startup either. I've unchecked it in System Preferences > User/Groups > Login items and it is still loading on login. I'd just like to remove it altogether temporarily. Is it as simple as dragging it out of the applications folder into the trash?
rotblitz
Level 6
Level 6
"Is it as simple as dragging it out of the applications folder into the trash?"
Yes, that should be it!  Why something else, different from any other uninstall?
unit1000
Hello, I'm trying to remove OpenDNS updater for Mac.
However, it's not appearing in the Applications list yet it does appear under login items.
How can I completely remove it.  It concerns me it's not identifying as an Application
rotblitz
Level 6
Level 6
Open a support ticket with OpenDNS, "Submit a request" above.
