ASR1001-HX
kuriakose1
ASR1001-HX Gave an alerts
Event: subslot 0/1 transceiver 1 Rx Power Sensor,
Anyone  know  does this error a concern or what command I can use on this platfrom to check the status
2 Accepted Solutions
 Can you run this:
show hw-module subslot 0/1 transceiver 1 status
Leo Laohoo
Means the Rx (receive) of the optics is too "faint".  Check the patch cable, the fibre path and, finally, check the optics at both ends.
5 Replies 5
 Can you run this:
sh hw-module subslot 0/1 transceiver 1 status
The transceiver in slot 0 subslot 1 port 1
has been disabled because:
the port is in shutdown state
Module temperature = +27.156 C
Transceiver Tx supply voltage = 3287.4 mVolts
Transceiver Tx bias current = 0 uAmps
Transceiver Tx power = -40.0 dBm
Transceiver Rx optical power = -40.0 dBm
 - Could be (received) optical power too low , you may also check current thresholds with : show hw-module subslot 0/1 transceiver 1 idprom detail
 M.
Leo Laohoo
