03-19-2019 11:54 PM
HI ALL,
I have on Cisco 2960X 24 port switch .Now I want to buy one 48 port switch .I am planing to buy 9200L.
and provide uplink will SFP ( 1Gb ) . Will it work ? ( 2960X computer need to talk with 9200L computer)
Please advise
03-19-2019 11:58 PM
2960X cannot be stacked with a 9200L. Both can be connected, using ethernet cable, and they will both act independently.
03-03-2021 09:11 AM
Hey leon, we have a 2960 x which we are trying to connect to a new 9200L via fiber and SFP. I cant get them to link. I used an older 3500 series switch and it linked right away, so I know my fiber and SFP are good. Can you give some insight into how to get then to link via fiber?
03-20-2019 12:16 AM
Adding to @Leo Laohoo comment, good to create a port-channle with 2 Links so you have resiliance.
04-04-2019 09:21 AM
it works
as long as you are using port-channel kind of "uplink" should be ok, and I quite like this, small switch low power usage. :)
03-03-2021 09:09 AM
I'm in the same situation. We just got a new 9200L and I tried to link it via fiber and SFP. But it wont link, I made both ports trunks. I had another older switch which we used to test and it linked right away to the 2960. Is there a config command chain to make them link.
03-03-2021 10:50 AM
Can you explain more with configuration to look, try no speed negotiation auto
03-03-2021 10:57 AM
03-03-2021 11:34 AM
example : change the interface
config t
interface gix/x
no negotiation auto
shut
no shut
end
03-03-2021 11:40 AM
03-03-2021 12:30 PM
Glad all working as expected.
