08-11-2024 08:48 PM - edited 08-11-2024 08:51 PM
Hi all, is there any way I could get any confirmation on whether if I can insert the Cisco SFP Module (GLC-LH-SMD) in a CBS350-24T-4X Network Switch with SFP+ ports. Googling didn't help much and users were warned about usage of 3rd party SFP Modules, SFP firmwares being the culprit when found incompatible.
Thanks!
Solved! Go to Solution.
08-11-2024 10:11 PM - edited 08-11-2024 10:15 PM
08-11-2024 09:09 PM
look at Cisco optics compatibility Matrix here
I see that GLC-LH-SMD will work with CBS350
08-11-2024 09:44 PM
That SFP Module is indeed compatible with the CBS350 Series of switches, however the switch I've selected to work with is stated to only support SFP+ Modules ie. 4 x SFP+. For cost saving purposes, if I decide to choose a 1G SFP Module, I would like to know whether that module will be recognized and will start functioning as expected.
Thanks!
08-11-2024 10:19 PM
Thank you very much for your kind help. That link does confirm and resolves my doubt.
Have a good day sir/madam!
08-11-2024 11:33 PM - edited 08-12-2024 02:39 AM
Dear @ryujin7177
Just want to share, in my current organization, we use WS-C2960S-24PD-L, with two SFP+ uplink.
If 1G sfp transciever is inserted, it will use 1G port 25, if a 10G sfp tranciever (SFP+) is inserted then it uses the 10G port 1/0/1 interface. (same with 1G port 26 and 10G port 1/0/2)
GigabitEthernet1/0/24 unassigned YES unset down down
GigabitEthernet1/0/25 unassigned YES unset down down
GigabitEthernet1/0/26 unassigned YES unset up up
Te1/0/1 unassigned YES unset up up
Te1/0/2 unassigned YES unset down down
switch1# sh ver
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960S-24PD-L 15.2(2)E9 C2960S-UNIVERSALK9-M
switch1#sh int g1/0/26
GigabitEthernet1/0/26 is up, line protocol is up (connected)
Description: {1G Uplink}
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
switch1#sh int te1/0/1
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
Description: {10G Uplink}
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
Note: Transceivers are all Cisco product.
Some links below for reference you might want to see
https://www.inscapedata.com/pdf/SFP_vs_SFP+_What_is_the_Difference_and_How_to_Use.pdf
A similar case also posted in the community, where you can change the XG port in CBS switch to use 1000M which in case the use of 1G SFP module.
https://community.cisco.com/t5/switches-small-business/cbs350-24t-4x-and-sfp-sfp-support/m-p/4386773
Image below from cbs350 test gui
Happy to Help :]
Best regards,
