08-05-2024 04:45 AM
https://tmgmatrix.cisco.com/?si=C93180LC-EX
Adding servers to the N9K-C93180LC-EX. Need 10G connectivity and see SFP-10G-SR on compatibility matrix but issue is it looks like this switch only takes QSFPs?
Is there an adapter required to make the SPFs work?
Solved! Go to Solution.
08-05-2024 05:22 AM - edited 08-05-2024 05:24 AM
Cisco Nexus 93180LC-EX |
Up to 32 x 40/50-Gbps QSFP+ ports OR 18 x 100-Gbps QSFP28 ports |
QSFP Ports, QSA (CVR-QSFP-SFP10G) required.
Mode 1: 28 x 40G + 4 x 40G/100G (If top port is configured as 10G or 1G using QSA adapter; the bottom port also needs to be 10G or 1G to match the speed).
Mode 2: 24 x 40G + 6 x 40G/100G (If top port is configured as 10G or 1G using QSA adapter; the bottom port also needs to be 10G or 1G to SFP match the speed). Port 26 and 28 are disabled.
Mode 3: 18 x 40G/100G (QSA is supported on all the 18 ports.)
